Rear suspension alignment
Old Jun 7, 2017 | 08:13 PM
jagskiguy's Avatar
Default Rear suspension alignment
2000 XJR; Recently had a four wheel alignment done and was told the rear suspension was out of alignment. I was told that there was no way to align the rear as no adjustments are available for the independent rear suspension components.
I have previously had such alignments done and no such issues had ever appeared.
Does a rear subframe exist on this car to which some adjustments could be made or cause the rear to be misaligned?
Old Jun 7, 2017 | 08:54 PM
motorcarman's Avatar
The CAMBER and TOE can be adjusted!!!!!!!!!!!!!!!!!!!!!!!
bob
Old Jun 8, 2017 | 01:45 AM
Originally Posted by jagskiguy
2000 XJR; Recently had a four wheel alignment done and was told the rear suspension was out of alignment. .....
I've moved your question from General Tech Help to X308 forum. This is the place to post technical questions about your model.
Old Jun 8, 2017 | 03:52 AM
Daim's Avatar
bob
Wasn't camber adjustable via plates between diff and drive shaft?
Old Jun 8, 2017 | 08:22 AM
Mark SF's Avatar
The answer to your question depends on how exactly it was out of alignment. Is that a secret?
Old Jun 8, 2017 | 08:32 AM
YES!!!!
Toe is adjusted with ECCENTRIC bolts on the outer lower control arms.
bob
Old Jun 8, 2017 | 08:35 AM
Mark SF's Avatar
And in my opinion, taking it all apart and shimming it, when the camber is even but slightly out of spec due to lower ride height from old springs, is ridiculous. Might as well shim it every time you put something heavy in the trunk.
Old Jun 8, 2017 | 10:31 AM
Samilcar's Avatar
Rear toe is dead-easy to adjust using the eccentric bolt. Rear camber adjustments are more involved. I too was told (wrongly) that no rear adjustments were possible when I paid for an alignment after replacing my steering rack. Rear toe on my rear passenger wheel was off enough that the car drifted slightly on the highway after the front alignment. I ended up adjusting it myself and it tracks straight as an arrow now.
Old Jun 8, 2017 | 11:46 AM
Brutal's Avatar
rear toe is adjustable. so is camber but not for the alignment inclusive price. I would never recommend unless camber is close to -2.0deg. Even then just drive harder in corners.
Digital Will
Feb 21, 2026 05:58 PM
D.K
Mar 28, 2020 09:48 AM
motorcarman
Oct 12, 2016 11:36 AM
bojangles
Jan 6, 2007 02:16 PM
