Rear wheelarch repair panels
Old Dec 1, 2012 | 04:23 PM
richard thomas's Avatar
Default Rear wheelarch repair panels
Could somebody confirm my thoughts as correct or not?
I have some corrosion on my rear L/H wheel arch. I will get it repaired but want to do it properly so I intend to cut out all of the old rust, and weld in a repair section. Only looking at about 4 cm but as with all rust it seems to go a bit further that it first looks...will do the welding and finishing myself, and get a bodyshop to paint for me.
Whilst I can look to fabricate a repair piece from steel sheet, I would rather get a repair panel and cut out the piece I need....But they seem hard to find.
Are the older X300 wheelarches identical to X308, as I think I have found one for an X300?
Old Dec 1, 2012 | 05:04 PM
Red October's Avatar
I've seen rear wheel arch repair panels for sale at: www.justjagsuk.com for £31.50 excluding VAT for the LH arch. It states that it can be used for the XJ40, X300 & X308 models so the rear wheel arches are the same on the X300 & X308.
Old Dec 1, 2012 | 05:11 PM
Nice one, I will have a look at that...
Nothing better than the crackle of the mig welder as new metal goes in :-)
Old Dec 1, 2012 | 05:14 PM
Better than the crackle of rust flakes falling off the old metal
Old Dec 1, 2012 | 05:39 PM
Yup, that's what will happen if i don't catch it soon....:-)
Will wait till early spring, going to use her all winter so might as well wait until the conditions are not so harsh....
Old Aug 14, 2013 | 07:18 AM
mgb4tim's Avatar
I know this is an old post, but I was a good lad and used the search function.
Does anyone know of a US supplier of x300/308 wheel arch repair panels?
Old Aug 16, 2013 | 10:27 PM
jimlombardi's Avatar
SNG Barratt USA website
SNG Barratt Jaguar XJ40/X300 Parts Catalogue
XJ40 wheel arch repair panel
RH CAP516RP 1
LH CAP517RP 1
WHEEL ARCH REPAIR PANEL RH PRODUCT CODE: CAP516RP RETAIL PRICE: $42.28 ($42.28) inc TAX
SNG Barratt - The Ultimate Jaguar Parts Specialist
WHEEL ARCH REPAIR PANEL LH PRODUCT CODE: CAP517RP RETAIL PRICE: $42.28 ($42.28) inc TAX
Just Jags UK website links
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - RH (CAP516RP-A) £31.50
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - RH (CAP516RP-A) - JustJagsUK.com
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - LH (CAP517RP-A) £31.50
Jaguar X300, X308, XJ40 Rear Wheel Arch Outer Panel - LH (CAP517RP-A) - JustJagsUK.com
Jim Lombardi
Old Aug 17, 2013 | 10:53 PM
CAP516RP - Rear wheel arch outer panel - right hand side.
This rear wheel arch outer panel will fit the Jaguar XJ40, X300, and X308 models.
Note; on the X300 and the X308 models you will need to cut off around 6 inches (150mm) of the rear section of the panel in order it will fit where the rear bumper (fender) meets the wheel arch.
The arch will not need this modification for the XJ40 models.
also applies to the LH CAP517RP - Rear wheel arch outer panel - left hand side
Info provided by JustJagsUK.com
Jim Lombardi
Old Aug 19, 2013 | 10:20 AM
mgb4tim's Avatar
Thanks Jim!
I saw the notes on the UK site about trimming. Not looking forward to this project. So, it will be some time before I even start it. But, I'll have the parts on hand when it's time.
FrickenJag
Jun 16, 2025 02:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
cissdm
May 3, 2016 06:02 AM
KarimPA
Sep 12, 2015 08:15 AM
obwoodie
Sep 3, 2015 07:45 PM
