Rear window brake light fell off
Old Feb 18, 2009 | 09:47 AM
wdmoreton's Avatar
Default Rear window brake light fell off
Hey guys
Hopefully a simple one for you. The eye-level brake light on the rear parcel shelf fell off ('99 XJR). It seems it was actually stuck to the glass. Any ideas what I should use to stick it back on ? I dont want to use epoxy glue if there is in fact a specific product I should be using.
Thanks in advance.
Old Feb 18, 2009 | 11:46 PM
Serbian Highlander's Avatar
Default 01 XJR Same Problem
I had the dealer look at it and they glued it back onto the window two times. It fell off the first time. After they glued it on they place a stack of paper towels under it which I kept there for a few annoying days. The second time it worked.
Old Feb 20, 2009 | 09:25 AM
joey4420's Avatar
Marine epoxy will attach anything to any window and stay there... just be careful not to use to much or it will be all over the window.
Old Feb 21, 2009 | 08:02 AM
AlleyCat's Avatar
Default This is how I did it. (03 XJR)
I went to the friendly neighborhood auto parts store and bought two rearview mirror adhesive kits. (This light is attached in the same way). You have to detach the metal contact pieces that attach to the glass and to the plastice frame of the light. Clean the pieces thoroughly to remove any old adhesive. Dryfit the contact pieces and mark the glass with a grease pencil around the outside of contact pieces. FOLLOW THE DIRECTIONS WHICH COME WITH THE KIT. Do one piece at a time since you need to hold it in place for several minutes and the adhesive from the first kit won't work by the time you get to the second one. After the pieces are stuck to the glass you need to wait, again follow the directions.
I think the reason a lot of people have problems with this is that the adhesive takes a while to fully bond. Even though it looks like superglue it is a different animal. Hanging a weight on it before it is set up leads to premature... failure.
Clean the grease pencil marks off the glass. In fact just go ahead and clean the whole area. This will be your last chance to get this part of the window clean without a hassle.
Snap the light in place and you are good to go. When you are done it will look like it did when it left Coventry.
Old Feb 21, 2009 | 02:41 PM
jag_genius's Avatar
any glass shop can do it for you for couple bucks.. sometimes they dont charge you ..
Old Feb 24, 2009 | 12:34 PM
wdmoreton's Avatar
Default thanks to all
Thanks fellas
Your help is greatly appreciated. Its back on :-)
Old Mar 1, 2009 | 10:02 PM
Sarc's Avatar
Smile And the award for creativity goes to.....
Step 1. Find a shoe box or anything that is made of stiff cardboard. (and preferably glossy cardboard the same colour as the car interior)
Step 2. Cut a piece out, bend it into a "V" shape and wedge underneath the offending falling off rear brake light
Step 3. Marvel at your creativity :-)
Old Jan 27, 2011 | 03:18 PM
obriendob's Avatar
Default cretivity still rattles when you hit a bump
Well
the cardboard post (or wood thatI use) does hold the light in an upright position. But, when I hit a bump, it gets loose quick and the rattle drives me crazy. If the weather in NJ ever gets better, Ill glue the light
Shawn Svacha
Nov 4, 2019 02:47 PM
jdzubas
Oct 4, 2015 09:14 AM
dcvickers
Sep 2, 2015 06:14 PM
OkieTim
Sep 2, 2015 12:48 PM
innzane
Sep 2, 2015 10:08 AM
