Rear window doesn't defrost
Old Dec 13, 2015 | 08:15 PM
Miss Charlee's Avatar
Default Rear window doesn't defrost
When I push the rear defrost button the window doesn't defrost at all.
Old Dec 14, 2015 | 12:05 AM
Mark SF's Avatar
Well did you check the fuse?
Old Dec 14, 2015 | 06:53 AM
avern1's Avatar
Attached is a diagram of the relay box in the boot. The back light heater relay is for the rear defroster. swap it with one of the relays next to it. If it works them the relay is bad and needs to be replaced.
File Type: doc
Old Dec 17, 2015 | 05:31 PM
Pilotman11's Avatar
I took out the relay and then put it back in; works again. Not too sure how that made it work again.
Old Dec 17, 2015 | 06:27 PM
Ok. I am going to switch the relays and see if that works. But first I'll try taking it out and putting it back in. Let you know what happens.
Old Dec 18, 2015 | 06:11 AM
avern1's Avatar
The relays will sometimes loosen up and loose contact. They will also corrode and lose contact. If taking it out and reinstalling it worked for the relay you might want to check and reseat the other relays on the board.
Old Dec 18, 2015 | 08:20 AM
Ok thanks. I will do that.
Old Dec 18, 2015 | 08:36 AM
yeldogt's Avatar
The relays are cheap to replace -- $12.
The internal relay contacts could be pitted depending on the frequency of use. The defroster is high amp. The contacts that you can see are rarely the problem -- the internals flex when you pull them out .. often realigning the internals. It may work for a while .. but will fail again.
Old Dec 19, 2015 | 09:35 AM
Oh, ok. I'll replace it then. Thanks for the heads up.
Old Dec 19, 2015 | 10:56 AM
yeldogt's Avatar
Don't replace unless you are sure that is the problem?
It's simple to switch out the relay with another one -- and you can easily test the fuse and if power is getting to the window.
Old Dec 19, 2015 | 08:23 PM
King Charles's Avatar
scottyg
Jun 15, 2022 12:11 AM
XKOwner
Dec 29, 2015 06:50 PM
Frank Hires
17
Dec 29, 2015 11:11 AM
Duncan2004
Dec 15, 2015 11:28 AM
RDMinor
Dec 12, 2015 10:27 PM
