Replacement for door handle gaskets?
Old May 17, 2017 | 05:59 AM
Daim's Avatar
Default Replacement for door handle gaskets?
Hey guys,
As I want to remove my door handles to paint them properly, I would need some new gaskets between handle and door skin. Mine are cracked and dead. No new ones out there as it looks.
Has anyone had any ideas what tomdo instead? Use silicone? Or maybe some dense foam cut to shape? Or what would you use?
Damien
Old May 17, 2017 | 07:42 AM
Samilcar's Avatar
Door Handle Seals Gaskets - Jaguar XK8 97-06 XJ8 98-03 X300 95-97 XKR 2000-06 | eBay
I haven't used these, but would like to hear from someone who has. My driver door especially needs this seal replaced as it's quickly crumbling away.
Old May 17, 2017 | 08:11 AM
Daim's Avatar
I'l buy some and see how they turn out
Old May 17, 2017 | 08:56 AM
Blue_XJ8's Avatar
This is awesome. I have been looking for these. And I have the exact same to-do on my list of things. Keep us posted!
Old May 17, 2017 | 10:46 AM
Daim's Avatar
Will do. Just bought them. Will see how they are and also how they fit (hopefully early June I'll get the car painted).
Old May 17, 2017 | 11:14 AM
although pricier than the ebay ones, Welsh also carries these - bought a set for my XK8 a few years ago and they work like a champ
Welsh Enterprises, Inc - Jaguar XJ8 (98-03) Body Fittings Front Doors Parts - Right Door Handle Gasket
Old May 17, 2017 | 11:18 AM
Daim's Avatar
A set if 4 would set me back a lot of cash! With transport and import duties... I'd be around €120 (easily) for 4 where as I am now only €35 poorer than before
Old Dec 27, 2018 | 09:16 AM
trottier.ed's Avatar
Default X308 Door Handle Gaskets
Welsh Enterprises (800-875-5247) in Steubenville, OH (Dean Martin's Birthplace!). Spoke to Amy X-166
Part # JLM-12031-GSK (Left x 2) @ $39.95 ea.
Part # JLM-12032-GSK (Right x 2) @ $39.95 ea.
These are much different (more robust) than the simple "oval" rings seen on eBay for $18.54 ea. These require door handle removal. I could not imagine "picking pieces" of OEM gasket (degraded and crumbling OEM), so will be having the Welsh gaskets fitted soon after New Year begins. It is a matter of water intrusion past crumbling (UV damage) OEM gaskets.
2003 XJR
Aiken, SC
Old Dec 27, 2018 | 10:18 PM
Scotlad's Avatar
I wonder if an exterior grade black silicon caulking would work for gaskets that are not too far gone. The exterior caulking would have u.v. inhibitors and would be a whole lot easier to do rather than taking all 4 doors apart. I have seen small tubes of this available.
