Reverse lights stay on
Old Sep 15, 2024 | 01:45 PM
Ian Gardner's Avatar
Default Reverse lights stay on
As in the title. Key out door locked and still reverse lights stay on.
I recently had the fuel pump replaced and noticed two things that don't look right. One is a plug and the other is a small hose. I'm assuming a vacuum linr
This is the plug
This is the hose
Old Sep 15, 2024 | 02:01 PM
Addicted2boost's Avatar
The plug in the top photo is normal. Just tuck it down behind the battery.
The second photo is a breather hose for your battery. It should be plugged in.
It plugs in the top of your battery under the hold down bar.
Old Sep 15, 2024 | 02:57 PM
Thanks for the info
Old Sep 15, 2024 | 04:47 PM
motorcarman's Avatar
And no need to post a question about the single wire for the TRANSIT RELAY. (it doesn't connect to ANYTHING)
Old Sep 15, 2024 | 04:56 PM
Parker 7's Avatar
Which year is your X308
this pic may cover your year
The SLCM is located above the fuel tank and the connectors may have been disturbed
Remove battery positive post and fully remove and reseat the SLCM connectors
The inputs to the SLCM in the pic's left may have been effected
Old Sep 15, 2024 | 08:08 PM
Thanks for the info I will check that out on my 01
Mago304
Aug 7, 2023 01:55 AM
Gmancuso
Apr 19, 2017 08:01 PM
JimsjagshopTX
Dec 20, 2016 10:18 PM
rscultho
Apr 25, 2011 02:13 PM
DRIVER12
Aug 17, 2010 04:55 PM
