sc heads on na block
Old May 8, 2017 | 11:05 PM
jcreaden's Avatar
Default sc heads on na block
just out of curiosity will the supercharged heads and cams bolt onto th na block and if so wouldnt it improve performance? may be a dumb question but had to see if someone else ever considered it.
Old May 9, 2017 | 01:56 AM
Daim's Avatar
If you are refering to SC on 4.0l na then no. The SC doesn't have VVT and it also isn'to different mechanically.
Old May 9, 2017 | 06:14 AM
Sean B's Avatar
Sorry to contradict Daim, but yes they do fit. No added performance. The heads are the same part number.
But the camshaft sensor reluctor(s) - 1 on an AJ26, 2 on an AJ27 need fitting if going from 26-27 or visa versa. The other thing is of course the VVT which will need fitting, the S/C cam 'flywheels' and timing chain sprockets are removed with 1 bolt.
Old May 9, 2017 | 06:25 AM
jcreaden's Avatar
hmm figured heads would fit with larger valve ports and that cams might be slightly larger. does anyone know if you can find performance cams for the aj26
Old May 9, 2017 | 06:55 AM
Sean B's Avatar
Not that I know of....that would be a specialist job = expensive. Valves and ports the same on all heads.
Compression ratio obviously higher on the NA engine.
Old May 9, 2017 | 07:17 AM
Daim's Avatar
I know the heads would fit, I didn't state they wouldn't I only refered to the cams...
Maybe I should write totally mega ultra super duper clear about things...
Old May 9, 2017 | 07:46 AM
jcreaden's Avatar
thanks guys cleared that up quick so looks like im limited to actual machine work then. im sure I can work the heads over and improve performance shave a little here port and polish there maybe even bigger valves I really want to stick with the original engine. even if it costs more thanks again y'all
Old May 9, 2017 | 07:54 AM
BobRoy's Avatar
Sean I plan to do the reverse of jcreaden. I plan to put heads from a 99 AJ27 N/A engine to a 2000 AJ27 S/C engine. (Dropped valve seats on S/C engine). So the heads and cams are the same. All I need to do is remove the VVT from the intake cam and install the sprocket from the S/C head.
Old May 9, 2017 | 08:41 AM
jcreaden's Avatar
are there higher compression pistons available at least anyone know
Old May 9, 2017 | 10:17 AM
BobRoy's Avatar
The compression on the NA engine is already 10.75 to 1.
You will need racing fuel if you go with a higher compression. What are you trying to acheive? The most cost effective way to increase horsepower is to sell your car and get an XJR. That's the easiest way to pick up 98 more horsepower.
Old May 9, 2017 | 10:32 AM
jcreaden's Avatar
wow didnt realize it was up there already and im starting to agree with you about getting an xjr but that will have to be the next time around. thank you guys for the info. seems like jag squeezed everything they could outta this engine without forced induction. back to the drawing board then. thanks again y'all
Old May 9, 2017 | 12:51 PM
motorcarman's Avatar
I will post this AGAIN!!!!!!!!!!!!!!!!!!!!!!!!!!!!
All the TSBs I have (that no one reads) are in the large file area on this forum somewhere and on Gus's site.
Jaguar answered this 18 years ago.
Going 'the-other-way', you will need to PLUG the hole for using NA heads on SC engines.
bob
File Type: pdf
Old May 9, 2017 | 01:09 PM
jcreaden's Avatar
excuse me for not knowing how to navigate the forum that well just had a question didnt need the rude to go with the answer thank you for your input
Old May 9, 2017 | 02:02 PM
BobRoy's Avatar
Thanks for the info Bob. I didn't think about the oil supply for the VVT needing to be plugged. This is a future project and might not get to it for another year.
Old May 9, 2017 | 05:59 PM
Sean B's Avatar
Yep. I carry out what Bob's TSB says...
Tap the gallery
Insert bolt, copper washer and a dab of threadloc
Done
Attached Thumbnails sc heads on na block-dscf5561.jpg   sc heads on na block-dscf5562.jpg
Old May 9, 2017 | 08:13 PM
omgimali's Avatar
80*
Old May 9, 2017 | 08:27 PM
BobRoy's Avatar
I was reading the ft lbs. I should use my glasses next time. Thanks for the clarification.
Old May 10, 2017 | 07:38 AM
Count Iblis's Avatar
The cylinder head castings are the same and the port geometry is the same NA to SC.
You would lose performance however as you'd lose VVT.
The compression ratio is lower on the SC variant but that is attained through different dished pistons rather than flat tops
