Simple breather hose fix
Old Mar 18, 2013 | 08:47 AM
Probesport's Avatar
Default Simple breather hose fix
I replaced my broken, taped, nasty breather hose with a nice rubber one that fits perfectly, gives an OE look and should give years of worry free maintenance.
I am sure I am not the first to do this but I figured since I was doing it I might as well take some pics for others.
Parts needed:
3/4" heater hose
Tools Needed:
Utility knife or razor
Pliers
Acetone / Brake cleaner (if desired)
Remove the old breather hose by pressing down on the clips and pulling upwards or outwards. Seen here all taped up by the previous owner
After removing the tape I was left with pieces. Slit the pieces that are on the barbed fittings on the ends and use a pliers to assist in removal.
Below is the hose I used
I used a bit of acetone to remove the lettering
Put on end on the hose and seat properly on intake tube, insert the valve cover fitting and mark for exact length. Leave a slight curve to allow for engine movement.
Press hose on remaining end. The barbed fittings and tight hose allow for a perfect seal, no need for clamps.
Stand back and admire your work.
Takes less than 10 mins and for me, I had the hose on hand so it was free too.
Attached Thumbnails Simple breather hose fix-tube1.jpg   Simple breather hose fix-tube2.jpg   Simple breather hose fix-tube3.jpg   Simple breather hose fix-tube4.jpg   Simple breather hose fix-tube5.jpg
Old Mar 18, 2013 | 03:11 PM
ross1's Avatar
Just so you know, heater hose isn't oil and fuel vapor resistant, both present in that crankcase vent line. It'll work until the rubber turns to goo from the inside out and collapses.
Old Mar 18, 2013 | 04:30 PM
Probesport's Avatar
Well aware and that takes a looonnnnnnnggggg time. I've done it on quite a few times. Fluorosilicone would be the best bet but I don;t have any in 3/4" and fuel line doesn't easily come in 3/4" either.
This will get through many years before it starts to degrade with the small amounts of oil it comes in contact with.
Old Mar 18, 2013 | 05:54 PM
Red October's Avatar
At least the hose is very easy to access & replace with a new section if this ever did happen in the future...
I did a similar repair method when one of the brittle plastic coolant breather pipes fractured during an O2 sensor replacement operation which required removal of the coolant expansion tank.
Old Mar 18, 2013 | 06:28 PM
avt007's Avatar
Nice fix. I had to do a similar one when I broke the bleed line from the radiator.
Ross has a point, but you can change it out easily for next to nothing. Or, go find a hose that fits the environment.
Old Mar 18, 2013 | 07:56 PM
plums's Avatar
PVC dishwasher drain hose.
Old Mar 19, 2013 | 11:53 AM
runnerpaul's Avatar
Hi Probesport, this is a great repair and one I will certainly do if the breather hose on my XJ8 has to be replaced. Thanks for posting.
Old Mar 19, 2013 | 01:22 PM
Probesport's Avatar
I just dug up some of the info on the new Goodyear hose (which I used) and they are worlds better than the dimestore junk from days past.
"Goodyear heater hoses are designed for vehicles that need custom-routed heater hoses. They meet or exceed SAE J20R3, D1 specifications, so they'll stand up to the heat. Goodyear heater hoses use rugged construction; they're manufactured from Versigard rubber, a compound highly resistant to heat, oil, and weather. Their patented knit reinforcement is made with Tylanar fabric, a material that also meets SAE J20R3, D1 requirements. So, when you want your hoses to outperform the competition, choose these Goodyear heater hoses to get the job done."
Old Jul 21, 2013 | 12:12 AM
xjay8's Avatar
Good job mate...sounds like a commercial ;o)=)
Seriously, modern quality hose material will outlast the car.
For a really sexy looking hose, you could take the fittings along to your local hydraulic hose joint and have a hose made up with shiny stainless swaged fittings...that would look really classy ;o)
Old Jul 21, 2013 | 11:13 AM
adam699's Avatar
I did the same thing over a year ago. Still didn't fall apart.
Old Nov 10, 2019 | 02:15 PM
Lance Mikaelson's Avatar
Default Broken right bank connection
Hello, I see you’ve all replaced the hose and whatnot, but I’ve got a different issue now. So the connection to the right bank of the engine, I’m not sure what the term to call it is, is broken. It cracked and the hose won’t stay in the engine anymore. Anyone have a solution to this? I’ve been using a c clamp and am failing to keep it in. I’m desperate enough to try using jb weld on it to keep it in while also using the c clamp. Any suggestions before I head down this route? Thanks in advance!
Old Aug 11, 2021 | 02:41 PM
JagZAR's Avatar
I have same problem, need connectors to make up new breather.
Dagny
Jun 11, 2024 01:06 PM
Bcrary3
Feb 21, 2023 04:29 AM
Jandreu
Jun 30, 2022 03:10 PM
flyrr100
Mar 14, 2016 06:37 AM
Richard_gib
Sep 12, 2015 07:08 PM
