Spacer Size Brembo Brake Upgrade X308
Hello,
does anybody know the minimum spacer size (in mm) required to fit the penta wheels over the brembo calipers of a Jaguar X308?
I've already searched in this forum, however, have not yet found a precise answer to my question.
The maximum size I am allowed to fit to my car (here in Germany) in combination with the penta wheels is 15mm, I hope this will clear the caliper..
I hope I don't need to buy a new set of wheels.
Any advice is much appreciated.
Welcome FwIcf...we would greatly appreciate it if you would introduce yourself here (it only takes a couple minutes and a site requirement) ....https://www.jaguarforums.com/forum/n...-intro-must-5/
13mm should clear regarding your inquiry. I that myself asked years ago and was given that answer.
Have you ever tried yourself fitting the Pentas with 13mm spacers?
Not yet, I have measured to the lip and it should clear with turning. I have the rotors and got some R calipers (have the rebuild kit and paint for them) I need to mod to fit. Its in line with some other things I need to have time for also...
Find a passenger floor board knock that happened while comparing HP with a Honda (shifted into 3rd and BAM!...he was still in the rear view, lol)...think it a trans mount, possible motor mount?
New amp and sub pkg...
Install fold back mirrors...
Shampoo the carpets...
Time for the bi-annual clay bar, wax, polish...may do one of those polymer finishes?
Here's the link where I was talking to Luc about Brembo's and spacers... https://www.jaguarforums.com/forum/x...wanted-128967/
I guess I'm just going to buy 15mm spacers and hope it fits, I'll let you know if it does.
My calipers have been glass bead blasted and I think I'm going to paint them next week with my airbrush, all seals are brand new too.
This would finally give a precise answer to my question.
If there’s enough space to go with a 15mm spacer I‘m willing to cut the studs, in case they protrude too far into the wheel.
I can't because I installed different wheels and sold the spacers. But from what I remember I think there was more than 5mm clearance. You could do a test fit of the caliper and use washers to space the wheel out and see what works.
