strange things happening
Old Sep 6, 2015 | 09:20 AM
motorhead69's Avatar
Default strange things happening
ok sooo ,, my #7 fuse (15 Amp) in the left heel board was out so my power mirrors, dome lights, map lights, manuel tilt telescopic, all didnt work ,, so i replaced the fuse all good so i thoght ,,, then i realized that when i put that fuse in it kill"s all tail, rear fog, and brake lights???? , take the fuse back out and all the tail lights work again?? any clues? on a side note my 99 XJR is in pristine condition with 131,000 miles on it , i purchased it from a 91 year old lady that was the original owner it i super clean and nothing has ever been messed with .
Old Sep 8, 2015 | 12:20 AM
Anybody???
Old Sep 8, 2015 | 01:42 AM
JagV8's Avatar
Get workshop manual, follow tests in it.
Old Sep 8, 2015 | 02:37 AM
ok sooo ,, ........
Welcome to the forum motorhead69,
I've moved your question from General Tech Help to X308 forum. This is the place to post tech questions about your model.
Old Sep 8, 2015 | 03:45 AM
andrew lowe's Avatar
Check the wiring around the boot/trunk hinge on the right hand side.
Where the hinge pivots it can break the wires.
Old Sep 8, 2015 | 07:20 AM
sparkenzap's Avatar
+1 on the hinge wiring!
Old Sep 8, 2015 | 10:03 PM
Thank you guys , you were exactly right ,, I took off the plastic hinge cover and found 5 broken wires !!
Old Sep 8, 2015 | 11:21 PM
Default getting better
ok so i put the wires back together at the trunk hinge and that fixed a lot of things but im still missing front fog lights, rear running lights ( all other lights work including rear fog lights ) and lights in the stereo system and climate contols??? any thoughts?
Old Sep 8, 2015 | 11:29 PM
sparkenzap's Avatar
fuses? Wiring errors? bad splices?
Old Sep 8, 2015 | 11:38 PM
been thru all the fuses ,, nothing
Old Sep 8, 2015 | 11:39 PM
the only splices are the ones in the trunk i just did and they are good
Old Sep 9, 2015 | 05:19 AM
sparkenzap's Avatar
Well, then it is time to start the sometimes painful task of chasing everything down with the schematic and a test lamp or meter. I like a testlamp for circuit tracing because it applies some loasd and is easier to see while lying on you back upside down!
The stickys have the JTIS manual with the electrical drawings and several kind forum members have separated them out - I am sure they will jump in and forward them to you if you ask. Make sure you have ther drawing for your model year. There are some changes year to year.
Also, if yoiu need advice tracing the circuits along the way, say the word after you have the schematic and a test device in hand.
Old Sep 9, 2015 | 08:50 AM
Jhartz's Avatar
It is possible your latest problem is with a loose wire (or more) in the multifunction switch, controlled by light stalk on the left of the steering wheel.
Search for multifunction switch; removing steering wheel; clock spring, etc for instructions on removing wheel and examining the switch -- rats nest of wires that control the lights you are missing.
Old Sep 9, 2015 | 10:04 AM
Bcrary3's Avatar
A note on the hinge wiring, check it all the way back through the insulation into the fuel tank compartment, that is where mine was broke at. I didn't notice it at first.
Forcedair1
Sep 8, 2025 01:57 PM
99xk8guy
May 28, 2024 09:36 PM
Armor6
Sep 14, 2015 07:56 PM
simo5555
Sep 9, 2015 06:22 AM
carelm
Sep 5, 2015 01:13 AM
