Sunroof headliner
Old Aug 8, 2009 | 08:07 AM
Fairlane500's Avatar
Default Sunroof headliner
03 XJR - I did a search and found a lot of info on the sunroof operation and the sagging headliner, but I wasn't able to find anything that addressed my particular problem. With the sunroof on tilt, the headliner under the sunroof is sagging on the right hand side. It appears to have somehow come unhooked from the sunroof itself. I tried to push it back to the proper position, thought it might snap into place but no luck. Anyone have any ideas or advice? Is this a complicated fix? Could it perhaps be glued back in place?
Old Aug 8, 2009 | 04:57 PM
Sparkers69's Avatar
Default Sagging headliner
I have an 01 XJR that had the same problem. Go onto autobahn.com and look for saggy stoppers - very cheap alternative and work a treat.
Old Aug 9, 2009 | 03:12 AM
Thanks - I found saggy stoppers at "autobarn.net" I'm going to take a look later this morning, but I'm not sure this would work on the sunroof portion of the headliner. In my case, it seems the whole section has come loose and dropped down, it's not just the fabric sagging.
Old Aug 9, 2009 | 03:19 AM
JagtechOhio's Avatar
That's a problem with one of the arms displaced from the sunroof tilt and slide mechanism. You have to pull the headliner panle out, remove the outer sliding panel, and hope you can identify and correct the tilt/slide fault without having to replace one or both of them.
Old Aug 9, 2009 | 03:38 AM
Thanks - When you say remove the "outer sliding panel", are you rererring to the metal sunroof itself?
Old Aug 9, 2009 | 03:42 AM
Yup, headliner panel pulls out the back when in tilt position, then get inside and remove three torx screws each side and remove outer (painted) sliding panel. Have a look, compare both sides, have a beer, have another look, and figure it out.
Old Aug 9, 2009 | 04:50 AM
Thanks for the advice and instructions. 'Specially the "have a beer" part.
Cheers!
Old Aug 9, 2009 | 04:53 AM
No problem. You'll see what I mean about the tilt and slide mechanisms, I could write 'till my fingers bleed and it wouldn't make them easy to understand.
Old Aug 10, 2009 | 10:12 AM
SuperSport's Avatar
On mine, one of the pins that hold the liner on the springs has broken. I'm assuming I will need a new liner panel? I'll see if I can find another fix, but that appears to be the correct way to fix it.
Old Aug 10, 2009 | 10:34 AM
pjkbrit's Avatar
same probelm on my 02....I got it latched back into place....took me an hour.....sunroof is fine as long as I don't use the tilt feature....nothing was broken....looks like crap design to me.
Old Aug 10, 2009 | 11:14 AM
yep, it's a miserable design and frequently fails. Funny, 'cause the the only thiing that ever failed on Series III was the roof motor or gear, and the only thing that failed on the XJ 40 was...well, nothing.
The added tilt feature inspired the creation of the very fragile tilt and slide mechanisms, and replacing them is alot more trouble than it should be.
Brit, at lest one of yours has a broken component on a tilt/ slide mechanism, or it would be tilting properly. Your fix is the best, no problem.
Super sport, I can help you with any of the parts if you plan on getting yours sorted out, PM me anytime. A picture to show the area of concern will save a thousand words.
1983turbojaguarxj6
Jan 11, 2025 10:28 PM
JungleJonny
Oct 5, 2015 03:52 PM
ArtyH
Oct 2, 2015 11:39 AM
BlacXJRcat
Sep 25, 2015 06:43 PM
