Time sensitive question
Old Mar 25, 2016 | 03:21 PM
dsnyder586's Avatar
Default Time sensitive question
Hi all, thanks for your answers in advance!
1998 AJ26 XJR dropped valve seat passe4nger side- I have AJ27 heads laying around do we:
1. Only replace passenger head with AJ27 head, or swap both sides?
2. should I keep the AJ27 camshafts with the AJ27 heads, OR do I use the AJ27 cams and swap the reluctor/gears?
THANKS!
Dave
Old Mar 25, 2016 | 03:49 PM
sparkenzap's Avatar
If you swap camshafts, I suppose you should set (or at least check) the valve lash. If you are not doing a head rebuild, i would go for changing the reluctor cam.
Old Mar 25, 2016 | 03:56 PM
dsnyder586's Avatar
How do you remove the reluctor?
Old Mar 25, 2016 | 03:58 PM
dsnyder586's Avatar
And thanks for the quick reply!
Old Mar 25, 2016 | 04:15 PM
dsnyder586's Avatar
Ok- here is what I have gathered:
1. cams from both heads have the same part number...so they must be the same size.
2. can use the AJ26 cams on the AJ27 heads since they are same part number
3. I was overthinking the process
4. Will use AJ27 heads with AJ26 cams and all should be right with the world.
Old Mar 25, 2016 | 05:28 PM
sparkenzap's Avatar
I can confirm the cams are the same, at least for an SC model- I swapped mine to a new head. But you are checking / setting up the valve lash, right? I am pretty sure the reluctors are just press fit, so a LITTLE heat and pulling would do it.
Old Mar 25, 2016 | 06:29 PM
Addicted2boost's Avatar
If I were you, I'd pull the reluctor off the AJ26 cam and install it on the AJ27 cam. Keep the AJ27 cams with their head and you MIGHT not have to adjust the valves. Adjusting valves is a time consuming PITA!!
Old Mar 25, 2016 | 07:52 PM
dsnyder586's Avatar
Ok- valve lash would be an issue- I am going to move the reluctor- has anyone done this before?
Old Mar 26, 2016 | 10:09 AM
I watched someone do it once. You must install the cam in a bench vise. This was a few years back but, I think he used a pipe wrench to twist it off and used a large brass hammer to install it. I'd highly recommend taking pictures of both reluctor positions prior to taking either of them off. Reason being is that if it's not clocked just right that it'll throw a CEL on. Then you'd have to reclock it while the cam is installed. Not fun. Take your time doing it because it's still easier than adjusting valves. Believe me!!
Old Apr 1, 2016 | 12:11 AM
dsnyder586's Avatar
Hey all-
Just wanted to follow up on this. Used two AJ27 heads, the drivers side cam from the AJ26 (same part# as the AJ27 cam) and checked valve clearances- all to spec. Buttoned up today and although there was QUITE A BIT of noise for a little while, it smoothed out and is running quiet and like a champ.
adam699
Aug 14, 2020 05:43 AM
Addicted2boost
Dec 18, 2016 02:48 PM
Jimmy 68
Mar 17, 2016 10:55 AM
NCamie
Mar 15, 2016 08:58 AM
Shelorr
Mar 9, 2016 08:46 PM
