Transmission oil leaking
Old Aug 25, 2014 | 06:56 AM
xjrsteve's Avatar
Default Transmission oil leaking
My car has oil leaking at the transmission as shown on the photo. The oil comes out after the car (and the engine) is stopped, and parking for more times. Is it a common problem for this MB trans, or not. What is the easiest way to cure it?
Thank you!
Old Aug 25, 2014 | 08:34 AM
RJ237's Avatar
The plug has a inner sleeve with two o-rings and bolts to the conductor plate inside the transmission. I'm not sure if you can disconnect the plug and replace the sleeve without moving the catalytic converter. The XKR has a heat shield in the way,also, but I don't see one in your picture. The fluid must be drained from the transmission to do this.
Old Aug 25, 2014 | 02:42 PM
motorcarman's Avatar
Jaguar issued a TSB (307-10) for this fault.
I uploaded it YEARS ago to this forum.
It explains everything.
bob gauff
Old Aug 25, 2014 | 03:19 PM
RJ237's Avatar
Can some one explain how to access TSB 307-10? I have checked the sticky on the forum and at jagrepair.com and do not find it.
Old Aug 25, 2014 | 05:39 PM
I uploaded ALL my TSBs to an account set up by TRANSLATOR.
I don't know if there is a MASTER LIST.
I never tried to find any TSBs on this site because I have all of them on my computers.
Here is 307-10
bob gauff
File Type: pdf
Old Aug 25, 2014 | 06:13 PM
RJ237's Avatar
Thanks, Bob. I haven't been working on the modern Jags for very long and have a lot of catching up to do. It's people like you that make it possible to keep these cars running.
Old Aug 25, 2014 | 06:20 PM
RJ237's Avatar
xjrsteve, it looks like you will have a fairly inexpensive repair. A new socket is available on ebay here, and I assume in Europe for just 2-3 euros.
Old Aug 26, 2014 | 02:17 AM
xjrsteve's Avatar
Yes, it seems easy to fix. Thank you for you guys!
aholbro1
Dec 29, 2024 06:46 PM
tomsjag
Jun 10, 2023 10:02 AM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
OkieTim
Sep 2, 2015 12:48 PM
