Troubleshooting T605 Install
Old Aug 30, 2013 | 07:17 PM
j020c's Avatar
Default Troubleshooting T605 Install
I've scoured just about every thread on bluetooth installs I could find in this forum. I'm using the Jim Roal bible, and I cannot seem to get my T605 powered up. I followed the wiring diagram verbatim,and can't seem to figure out what I'm doing wrong. Has anyone else run into this, or am I just the town idiot today?
Let me know if you have any pointers. Thanks!
Old Aug 30, 2013 | 07:58 PM
WhiteXKR's Avatar
Do you have a multimeter? Can you check for 12 volts and ground as a start?
Old Aug 31, 2013 | 12:19 AM
j020c's Avatar
I don't, but maybe I should add that to my list...
Old Aug 31, 2013 | 12:39 AM
avt007's Avatar
Doesn't it do anything at all? No lights?
Old Aug 31, 2013 | 03:12 PM
WhiteXKR's Avatar
I took a gander at Jim Roal's document, and although the wires are correct, the location of the fuses is different from what he specifies on a 2001.
For your car, make sure you have a good 5 Amp fuse in position #4 in the TRUNK fusebox and a good 5 amp fuse in position #22 of the TRUNK fusebox.
If not, add those fuses.
Old Aug 31, 2013 | 05:58 PM
j020c's Avatar
To avt007: no lights whatsoever...
To WhiteXKR: I was working on the Bimmer part out today. I may have some time tomorrow to verify those fuses, and get a multimeter on the lines to see what's going on.
Thanks for the feedback, guys...I'll keep plugging away!
Old Sep 1, 2013 | 02:39 AM
Maninahat98's Avatar
I get so much value out of a multimeter it's amazing and one doesn't have to spend a lot of money on it either...I bought something like this one (actually I bought 2, one for the house and one to keep in the garage).......A quick search on ebay for example provides lots of products - IMHO spending a lot on one is unnecessary for DIY auto electrics, but the benefits......
DIGITAL LCD VOLTMETER MULTIMETER CIRCUIT TESTER AMMETER AC DC METER OHM | eBay
Allan.
Old Sep 1, 2013 | 10:23 PM
j020c's Avatar
Default All good now!
WhiteXKR gets the door prize...#22 fuse was blown in the trunk. She's installed and functional, but I do plan to redo the wiring, relocate the mic, and clean it up a bit. I'll hack the CD changer next with a switchable input, and then I should be good to go!
Thanks for the assist, everyone!
dsnyder586
Dec 29, 2024 07:39 PM
aholbro1
Dec 29, 2024 06:46 PM
Majik Lasers
Aug 2, 2024 01:49 AM
Dagny
Jun 11, 2024 01:06 PM
explorer364
Sep 11, 2015 05:44 PM
