VCATS Listing - How to use it
Old Nov 2, 2014 | 09:34 AM
jimlombardi's Avatar
Default VCATS Listing - How to use it
After looking at our VCATS (Vehicle Configuration And Test System) List in the trunk, I wanted to learn more about it.
In the following 2 JPEG files are a sample VCATS listing showing:
the abbeviations for the control modules listed along its control module (part name).
Also a photo showing the VCATS location in the trunk (boot).
The VCATS Listing gives the Control Module abbeviation, then its part number, then its program revision number (suffix - ie /008) in the following example:
SLM LNG2600HB/008 --- SLM is Security Locking Module, LNG2600HB is the part number, /008 is the program revision number.
Also here is a PDF file on TSB 418-03 AM that has more detailed information on the VCATS:
https://www.jaguarforums.com/forum/a...patibility.pdf
Recent EBAY listing (ended Jan 3rd 2014) Used condition: JAGUAR XJ8 X308 SECURITY LOCKING MODULE LNG2600HB with Remotes
JAguar SCLM LNG2600HB with matching paired remotes LNG2600HB – Security Control Locking Module security code 008.
Rare Excellent working condition. Plug-n-play to solve your existing SCLM issues.
Jim Lombardi
Attached Thumbnails VCATS Listing - How to use it-jaguar-x308-vcats-listing-info.jpg   VCATS Listing - How to use it-vcats-list-location-listing.jpg
Old Nov 2, 2014 | 10:01 AM
andrew lowe's Avatar
Thanks, this should make things a bit easier if I ever need to replace a module.
Among the paperwork with my car, is an A4 sheet of paper that I assume is the build sheet. It has 12 barcodes ...
JAGUAR BODY
VIN PREFIX
VETS
CHASSIS NUMBER
PECUS
VIN
WHEEL ALLIGNMENT SETTING
HEADLAMP SETTING
ROLLING ROAD FACILITY
VIN STAMPING FACILITY
and 2 barcodes for VCATS
If it is not the build sheet, anybody got any ideas as to what it is ?
TIA Andy
Old Jun 15, 2025 | 07:03 AM
larrygee's Avatar
Jim Lombardi
Now, THIS was a great Post and Help! Thank You. I didn’t stumble across this post when I was searching.
Sparky565706
Mar 20, 2024 08:50 AM
fast feline
Jul 30, 2023 10:51 PM
arthurdaley
Jan 3, 2013 11:04 AM
99txxjr
Jun 18, 2012 08:17 PM
Teegig
May 26, 2011 10:04 PM
