Vertical connections/Hubs: early vs later
Old Apr 15, 2018 | 07:09 AM
Daim's Avatar
Default Vertical connections/Hubs: early vs later
Hey there,
while I'm giving my suspension a thorough workover, I've come accross the differences in wheel bearings due to different hubs. I am aware of the difference in hubs or better said in the uprights/vertical connections. But were they better?
Reason I am asking is simple: I always keep on experiencing warped discs/rotors. The discs though aren't warped but they act like it. So my guess is the bearings are toast which I would put down to the old style smaller bearings just not being as durable as they could be...
Is it worth upgrading to the larger wheel bearing hubs? I'm going 325 mm brakes in the front and also need wheel bearings and will be having the entire axle apart...
Damien
Old Apr 15, 2018 | 08:19 AM
avern1's Avatar
You post doesn't tell us what you are working on, but I encountered the same problem on my XK8 1997 when doing the front wheel bearing. The larger bearing came on the updated hub. The problem is on early models the left and right hubs are identical and on the later model the hubs are specific to each side. They also changed the mounting points and changed the location of the caliper mount.
As such I had to stay with the hub I had and replace the bearing in lieu of replacing the vertical mount. The earlier used the smaller diameter wheel bearing. The difference in size is so small I don't think it makes one better than the other.
Old Apr 15, 2018 | 08:33 AM
motorcarman's Avatar
The 1999MY onward use the Vertical Links with the larger 80mm bearing.
The early cars used 76mm bearings.
You can swap the later Vertical Links if you can find some in a salvage yard.
bob
Old Apr 15, 2018 | 09:43 AM
Daim's Avatar
Erm, I posted in the X308 section... So I would guess I am working on an XJ The upright is interchangable. Okay, I wasn't aware of the difference in the hub itself...
bob
Should be no worry but is it worth it? The bearings are larger, so I assume they didn't make them larger for no reason... There must be some kind of technical reason (bearing wear, stability, wobbles, ...)... Do you know of anything there, Bob?
Damien
Old Apr 15, 2018 | 12:49 PM
Samilcar's Avatar
Is it possible that you have uneven brake pad deposition on the discs? If you've measured the discs to ensure that they aren't physically warped, but they still behave as if they're warped (judder or pulsation during braking), you might have slightly more brake pad material transferred onto only certain parts of the disc, causing the pulsation.
Bedding In Brake Rotors
Old Apr 15, 2018 | 01:03 PM
Daim's Avatar
The judder only comes in after a longer periodisch of driving. The longer the worse. Measured with a very fine gauge ans there is no wobble or warping noticeable - when cold.
Discs and pads were always driven/bedded in. It has happend on several different pads and discs.
Calipers work both perfectly. No binding or sticking...
Old Apr 15, 2018 | 07:56 PM
I have replaced dozens of 76mm bearings but very few 80mm bearings. I guess the larger bearings are what the car needed from the start????
bob
Old Apr 15, 2018 | 10:08 PM
Daim's Avatar
bob
That sounds quite what I had in mind... Larger bearings normally last longer.
Thanks Bob!
jaguarmarkv
General Tech Help
Mar 23, 2016 06:12 AM
texaspete
Oct 27, 2013 09:42 AM
diverguy
Feb 10, 2011 12:02 PM
qwiketz
56
May 14, 2010 11:38 AM
mep
Jun 17, 2008 09:19 AM
