What did you do to your X308 Today?
Old Jun 13, 2024 | 11:49 PM
  #4941
24ounce's Avatar
Set the wheels out to the fenders and added a rear lip
Old Jun 14, 2024 | 06:09 PM
  #4942
Philip_A's Avatar
I received an engine.
Phil
Old Jun 18, 2024 | 08:14 PM
  #4943
Philip_A's Avatar
Made a rig up to lock the crank.
Must've put about 800lbft on it and it just told me nope.
Plan B beckons
Old Jun 19, 2024 | 07:12 AM
  #4944
Addicted2boost's Avatar
Phil, if you have a full size floor Jack, remove the Jack handle and put it over the breaker bar for more leverage. It could snap the breaker bar so be careful. I myself as well as many other people have ran into the same issue. From the factory, that bolt has Loctite red on the threads. Red = 💪🏻
Old Jun 19, 2024 | 07:29 AM
  #4945
Philip_A's Avatar
I added a cheater bar but that is only 1/2" drive and was beginning to make some unhappy noises.
Instead I may try the starter motor trick. Tie the engine down, get a bigger 3/4" drive bar and see if that shifts it.
Wonder why they specced it that tight.
Old Jun 19, 2024 | 11:59 AM
  #4946
Ken Cantor's Avatar
Plan B beckons
That wouldn't be a '66 Ford Fairlane you keep showing glimpses of in your pictures would it?
Old Jun 19, 2024 | 12:32 PM
  #4947
Quadcammer's Avatar
if you have a big cordless impact, it should get that off no problem. I used my 3/8" dewalt, which is a monster for its size and it came off. Some say that impacts are not the best choice due to vibrations, but I never noticed any issues.
Old Jun 19, 2024 | 12:37 PM
  #4948
Philip_A's Avatar
Ken,
1966 yes, Ford no. It's a Plymouth Fury. Currently on the back burner needing a bunch of welding.
​​​​​Phil
Old Jun 19, 2024 | 12:38 PM
  #4949
Philip_A's Avatar
Yeah, that's coming in at Plan Position B, I think. I've got a 3/4" drive windy gun that's more at home taking truck lug nuts off. I think I'll have to dig it out.
I ran out of time and weather yesterday.
Phil
Old Jun 19, 2024 | 07:35 PM
  #4950
nilanium's Avatar
Swapped front brake pad compounds over the weekend just for testing, and on the drive home from work, decided to try a few spirited stops now that the pads had bedded in a little bit... And the front end LIFTED up while heavy on the brakes, and slammed back down as soon as brakes were released.
Guess it's time for new Vee mounts. Both the fronts separated... Sucks cause the ones on there are only a few years old, and fairly low mileage, but I guess that's the cost of running aftermarket. So, shelled out hundreds of bucks for a pair of OEM ones, hopefully they hold up better to spirited driving/braking, otherwise some more involved/custom solution may be needed.
Old Jun 20, 2024 | 05:35 AM
  #4951
Vauxi's Avatar
At tuesday got her out of hibernation. Went straight to the MOT inspection and it passed with flying colours. Yesterday I did basic yearly service and today new spark plugs. Runs like a jag supposed to run.
Old Jun 20, 2024 | 06:46 AM
  #4952
Hooli's Avatar
I bought my XJR a present yesterday & it's arrived already. A Foxwell NT680pro, which hopefully I won't need much. Been saying I've needed a decent scanner for a while that does more than basic engine codes, saw these on offer from Gendan at £295 rather than £399 so it seemed rude not too. https://www.gendan.co.uk/product_FXNT680PCL.html if anyone is interested.
Old Jun 20, 2024 | 07:35 AM
  #4953
Philip_A's Avatar
I ordered one of those for my old man. Despite everything having been paid customs seized the entire contents of the container it arrived in at the docks and needless to say it never arrived.
Old Jun 20, 2024 | 08:03 AM
  #4954
RandyS's Avatar
Default Customs
I have always wondered what happens to the articles seized in a whole container
when only part of the container violates the customs laws. I would be willing to bet
it happens a lot more than one might think.
Old Jun 20, 2024 | 08:25 AM
  #4955
Philip_A's Avatar
Most likely eventually gets sent to auction.
I found my impact wrench.
We'll see if that frees up the crank bolt.
Old Jun 20, 2024 | 10:19 AM
  #4956
Hooli's Avatar
How damned annoying, I bet you don't get repaid for it after that happens either.
Old Jun 20, 2024 | 06:28 PM
  #4957
Philip_A's Avatar
Hah!
Plan C worked.
Phil
Old Jun 20, 2024 | 06:43 PM
  #4958
Your not done yet until that pulley is off and nothing else is broken. 😄
Old Jun 20, 2024 | 06:47 PM
  #4959
Philip_A's Avatar
One step at a time!
Old Jun 21, 2024 | 09:51 PM
  #4960
Philip_A's Avatar
Only the tool broke, today.
Bigger tool time. Going shopping tomorrow.
