What did you do to your X308 Today?
Old Jan 20, 2014 | 03:40 PM
  #521
OldMike's Avatar
I ordered an O2 sensor - should be here any day now -- can't wait to have that fixed so I don't have use my OBDII code reader to erase the code every time I start the car! (I hate driving with the CEL lit).
Old Mar 9, 2014 | 06:13 PM
  #522
FirstJag7979's Avatar
Post Getting my baby working properly
Today i am sorting out various electrical gremlins. Love my Cat but wish it was easier to find pictures of some parts. I have a downloaded service manual but the title says XJ series 2001. Hoping this will work on my 2003 XJR. Haven't had time to work on her much but this forum is incredible and the people are too.
Old Mar 9, 2014 | 07:21 PM
  #523
grandell's Avatar
Replaced brake disks and pads over the weekend. Unfortunately something's gone wrong with the right front, and sometimes there's a metallic grinding noise when turning left.
Sounds like something hitting either the stone guard, or the back of the disk. So some time this week I'll have to pull it all apart again and check what's going on.
Old Mar 9, 2014 | 08:18 PM
  #524
jimlombardi's Avatar
Hi FirstJag7979
You must have downloaded the 2001 thru 2003 XJ Series Electrical Guide PDF file (multiple PDF file names (3 of them)- X3082003en, also jfj2002en, and jzj2001en).
Apparently since all 3 model years actually use the 2001 XJ series electrical guide PDF file contents that probably means that the no changes were made in the guide since 2001 for the next 2 years (2002 and 2003).
Jim Lombardi
Old Mar 11, 2014 | 08:07 PM
  #525
WickedJag's Avatar
Finally dug out the garage door to access the car. Snow, Snow and more snow! How I miss thee.
Old Mar 11, 2014 | 08:25 PM
  #526
OldMike's Avatar
I replaced the passenger side cam cover gaskets. Pretty straightforward job.
Old Mar 12, 2014 | 03:40 PM
  #527
grandell's Avatar
Pulled everything apart last night and found the issue... there were two small stones lodged between the stone guard and the lower wishbone, and when the wheel was turned these were putting enough pressure on the stone guard to cause it to grind against the disk.
Stones removed, and a quick smack with a crowbar for a bit of extra clearance, and the brakes are perfect again
FYI the calliper bolts are T45 Torx, NOT 7mm hex.
Old Mar 12, 2014 | 04:18 PM
  #528
Superman001's Avatar
Fitted a new Wix air filter thats made in Poland and looks identical to the Jaguar one I removed that is also made in Poland.
Old Mar 12, 2014 | 05:08 PM
  #529
King Charles's Avatar
Car got here monday today I had the oil,coolant & tranny flushed.
Old Mar 12, 2014 | 05:13 PM
  #530
How many litres of trasmission fluid did it take to do the flush?
Old Mar 12, 2014 | 05:16 PM
  #531
Invoice reads 8 not sure if it's litres or quarts though.
Old Mar 12, 2014 | 05:57 PM
  #532
Not sure what a quart is being from the UK but if I had to guess I would say a quarter of a gallon or 1.135 litres?
Old Mar 12, 2014 | 06:21 PM
  #533
Quart = 32 ounces here. Would be 0.946353 litres.
Old Mar 12, 2014 | 07:31 PM
  #534
firenfix's Avatar
Replaced the clock light bulb, pretty easy just had to pry carefully on the passenger air bag wood trim to get the clearance I needed. Looks SWEET!
Old Mar 13, 2014 | 12:05 AM
  #535
Wanted to have the differential drained as well but this shop said they couldn't handle a Jag's said I should try a dealer, there is no dealer with in a 100 miles though. I'll look around I'm sure one of these small import shops can handle it.
Old Mar 13, 2014 | 04:06 AM
  #536
grandell's Avatar
Pretty sure you have to drop the whole rear subframe to do the diff oil. It's not hard, just takes a bit of space. Make sure you clean the breather on the top of the diff while you're at it! They clog over time, causing pressure to build up, which can lead to leaking pinion seals.
Old Mar 13, 2014 | 07:47 AM
  #537
xjay8's Avatar
Hell man....are these guys useless or what!
It's easy peasy....no dropping of subframe...no shifting anything;o]
All you need is up on the hoist...at back of diff on the upper side of the rear alloy plate you will find a plug with a square hole in it.
Use a 1/2" drive handle which will fit the plug or a wrench designed for the purpose.
Slip it into the plug at such an angle to be able to give it a good quick thump to break open the plug.
Then, use a suction gun to suck out the old oil.
These things hold around 900ml which about a pint I think.
If the oil has never been changed, it will stink like you wouldn't believe ;o))
Replace with any good quality full synthetic 85W90 GL5 rated oil.
Fill to start to to drip and wait until stops dripping ad replace plug.
The original washer should be fine.
I always add a diff additive into the 900ml mix...stopped my r/h side output seal from leaking ;o)
Old Mar 13, 2014 | 11:55 AM
  #538
Just bought Rockford Fosgate Punch P152's to replace the dated factory speakers front & back in the Jag, getting them installed in the AM. The left front is blown w/ cracked grill the rattling/popping is annoying lol. Gonna look into getting a 8-10 inch ported sub & amp as well.
Attached Thumbnails What did you do to your X308 Today?-x575p152-o_front.jpeg
Old Mar 13, 2014 | 07:56 PM
  #539
Well after 2 days of mid 70's FH weather it's down near freezing & the heater is not working,engine temp.'s normal & all the fans come on. With my recent coolant system flush(yesterday) I'm hoping it's just air or a stuck valve somewhere, grrrr err brrrrrr lol.
Old Mar 14, 2014 | 01:28 PM
  #540
Had all factory speakers replaced & 2 12' Memphis Car Audio subs in a ported box installed in the trunk.
Had my coolant system inspected for air there was none, so now the no heat issue thickens, I plan on searching the forums & checking fuses etc.
