What did you do to your X308 Today?
Old Mar 25, 2014 | 07:58 AM
  #561
JaguaXJR's Avatar
I spent what seemed like an ungodly amount of time researching this (every time I do), and finally wound up calling this company: iP-JAGCD iPod Adapter for Select Jaguar with CD Auto Changer :: iPod Adapters & Interfaces
I got voicemail, which really put me off, but I left a message anyway, and then had to go work.
I got a call shortly after from the company; I ducked into the house and got on the web site and we talked. He asked questions about my car and stereo system, all geared to determining which unit was right for me; I thought that some of the other companies didn't understand the options correctly, but this guy did - it's almost as if he'd done it for his own car last week.
I had the Alpine system, a CD changer, and an amp. He told me how to find all this in the trunk without tearing out the trunkliner. I was started to get impressed at this point.
I got back to the online catalog and I ordered a couple other parts (a iPod holder) and another, unrelated gizmo.
It came in a few days, and apart from my not finding the EXCELLENT instruction sheet complete with pictures (right away, it was on his web site), it was a piece of cake.
Running the wire from the rear seat to the trunk wasn't bad, once I figured it out, and I am waiting for warmer weather to bury it under the carpet.
I LOVE IT! ! ! ! !
All the music I own, ready to play, and the sound is excellent.
I wanna road trip.
Old Mar 25, 2014 | 09:27 AM
  #562
Probesport's Avatar
This past week I tackled a laundry list on my X308.
1) Change Fuel Filter
2) Replaced all fuel injectors with flow matched reman units
3) Replaced Spark Plugs
4) Added Priority Start
5) Repaired/painted rusty fender lips
6) Undercoated wheel wells
7) Painted lower sills (at pinch rail) black
8) Replaced Oxygen sensors
9) Changed transmission fluid and filter (changed fluid 3 times; once each a day)
10) Replaced all braided ground straps
11) Changed majority of vacuum lines to silicone
12) Change VC gaskets
13) Rotated tires
14) Put in aluminum stat housing, stat and coolant flush
15) Lubed all grease zerks (love my new cordless grease gun!)
16) Repaired a few exhaust leaks, had to re-weld RR muffler and replace small section of pipe
17) Replaced LR muffler with lower mile unit, old was was rotted in few spots
18) Disassembled and cleaned ignition coils, very corroded
19) Changed leather Oatmeal shifter surround to black plastic one - I like the wider chrome trim and matching to the stereo/HVAC
20) Added chrome door handle covers
Probably more that I'm forgetting but this car drives like new and at idle you'd have to look at the tach to see if the cars running. I need to do a sheet of everything done, it's quite extensive at this point.
Now I can turn my attention to the wife's 7 series that needs brakes, knock sensors, etc.
Old Mar 25, 2014 | 11:00 AM
  #563
radebusk's Avatar
Default Vanden Plas
I just installed slotted drilled rotors and ceramic pads at all four corners of my Vanden Plas. Ok I found a guy to do the labor cheaper than my time is worth. Getting ready to take it to cars and coffee. Nice to have her back in service. I think she purred.
Old Mar 25, 2014 | 12:27 PM
  #564
Zorasmiles's Avatar
Originally Posted by grandell
I could possibly be keen on one of those MS-8's in the future too... so keep me in mind if you do ever sell.
While I'm obviously still waiting to hear the final result, I must admit I'm loving the box built into the side of the boot. If I was to run a 'normal' sub with the motor on the inside of the box, then I would still have plenty of boot space left over.
I will keep you in mind if I sell one of the MS-8's. First demo I heard with the MS8 added to a system made me run out and purchase two. I figured when the wife purchased her new vehicle it was an easy way to upgrade the sound system and respect her "hands-off" approach to additional car audio lol
Old Mar 27, 2014 | 08:34 AM
  #565
Probesport's Avatar
Ordered new wheels and tires from CarID.
Old Mar 27, 2014 | 09:15 AM
  #566
NJ2003XJ8's Avatar
13) Rotated tires
If my car sees this - I will get a nasty divorce...
I got her new wiper (by bosch, works good) and fixed that little connector where wiper hose connects. It was broken and I could not find replacement part online, nor I could figure out how to easily access it. So I took a piece of pipe that fits (from a ball-pen), stuck it in and used "magic putty" from my plumbing toolbox to secure it - it works :-)
Old Mar 27, 2014 | 09:32 AM
  #567
Probesport's Avatar
In all fairness to your auto-spouse, I am a car guy so I tend to spend a lot of time with all my cars and am also well equipped to do so.
Cold Michigan weather and a heated garage helps
Old Mar 27, 2014 | 10:43 AM
  #568
NJ2003XJ8's Avatar
... with all my cars ...
We are exclusive :-) , I also got mine new pair of shoes few days ago (Falken Ziex ZE 912), she seem happy for now!
Old Mar 27, 2014 | 04:59 PM
  #569
Jhartz's Avatar
Replaced the aerial; piece of cake job following Rob Spinner's superb video. Installed the parts Mark sent from the junkyard.
Two weeks ago, replaced the water pump I installed last year (a two piece unit, been leaking since new) with an AC Delco unit: no leaks!!
Oil change a week ago. Ready for road trip.
Old Mar 30, 2014 | 04:16 PM
  #570
firenfix's Avatar
Default New thermostat housing
Installed a new aluminum thermostat housing from Welsh this morning. Took a couple hours including heating and bending a couple of 8mm wrenches for those tricky bolts in the back. All and all, pretty easy job.
Old Mar 30, 2014 | 06:55 PM
  #571
deancantrell's Avatar
I used the clay bar on the paint and waxed it, it made a difference.
Old Mar 30, 2014 | 08:47 PM
  #572
grandell's Avatar
Main amp rack is done!
The bottom one just needs to be covered in black 'brushed metallic' vinyl, the same as the small border around the DLS A3's that run my front speakers.
Then a bit of carpet, and wiring for the sub amp and sub itself, and we'll be almost finished
Attached Thumbnails What did you do to your X308 Today?-dsc05839_zps1e7a4d35.jpg
Old Mar 30, 2014 | 08:59 PM
  #573
King Charles's Avatar
Just bought the chrome door handle trim.
Jaguar XJ8 XJR Mesh Grille, Spoiler, Headlight Bulbs for Jaguar XJ8 XJR
Old Mar 30, 2014 | 09:02 PM
  #574
Probesport's Avatar
Sounds like you were able to do this without pulling the manifold. Pics of your custom wrenches?
Old Mar 31, 2014 | 06:56 PM
  #575
firenfix's Avatar
Default Custom bent XJ8 wrenches
Yes, did not touch the intake manifold and did not remove the radiator hoses from the radiator (just tied them back out of the way). Used the larger wrench to break free and snug the rear thermostat housing bolts and the shorter one for the many, many small increments of turning the bolts. All and all, very easy with a little patience.
Old Mar 31, 2014 | 07:00 PM
  #576
firenfix's Avatar
Default Wrench pics
And this time with the pics
Attached Thumbnails What did you do to your X308 Today?-20140331_194535.jpg   What did you do to your X308 Today?-20140331_194613.jpg   What did you do to your X308 Today?-20140331_194649.jpg
Old Apr 1, 2014 | 07:06 AM
  #577
Probesport's Avatar
Cool, almost makes me want to do it again
Old Apr 3, 2014 | 10:00 PM
  #578
ericjansen's Avatar
Came back from an EU trip with 2 suitcases full of parts, new and second hand. Pic shows just a small selection from what I carried back.
Imagine the reaction on the airport, if you run your hand luggage with a Jaguar Instrument Cluster through the X-ray machine
Now I can work my way around in getting a long list of small issues done, to make the car even better then it already is.
First on the list was removing, repairing and cleaning up the spaghetti of wires in the trunk, where they spliced a NAV system, a DVD player and the rear parking sensors into the main radio cable. Going minimalistic, I kept the rear sensors, but removed the NAV and DVD player.
Reward from cleaning up is, that all my speakers work again, there must have been some bad connection in all those looms.
Attached Thumbnails What did you do to your X308 Today?-wp_000797_zps0947c76e.jpg   What did you do to your X308 Today?-wp_000804_zpse963876f.jpg   What did you do to your X308 Today?-wp_000806_zpsbd39ac28.jpg
Old Apr 3, 2014 | 10:08 PM
  #579
ragman1171's Avatar
My passenger mirror fell out of the housing. I learned that the internal bracket had been broken and Gorilla Glued (if you were ever in the Army, you know what it is) together. Well, that glue finally failed. As the bracket it broken AND half missing, I did a band-aid fix (more gorilla glue) until the replacement housing I ordered arrives at which point I will have it installed.
Old Apr 3, 2014 | 10:22 PM
  #580
USMC here & Gorilla glue & tape has patched me through body molding & other car fixes so well I forgot I'd only temp. patched until it fell off @ high speed, ages later lol.
