What did you do to your X308 Today?
Old Apr 18, 2014 | 11:39 PM
  #641
Don B's Avatar
Originally Posted by RandyS
Yes, Tennessee is also under attack by the dreaded pollen.
I MUST figure some sort of electrostatic charging utensil which will repulse the negatively charged pollen and dispense with the brownian motion of pollen.
Do you think it might sell?
Sign me up, Randy! I'm suffering the same green pollen attack.
Cheers,
Don
Old Apr 19, 2014 | 01:06 AM
  #642
grandell's Avatar
I think my o2 sensors are on the way out, again. I'm sure it's been less than a year since I had them replaced, so I won't be impressed if that's the problem.
Managed to get my hands on a proper scanner. Wrote the codes down on my phone, but then it didn't save for some reason......
ok, so the reason might have been that I was too busy playing with the stereo, which is now finished!
I'll check the codes again tomorrow...
Attached Thumbnails What did you do to your X308 Today?-2014-04-16_20-30-10_398_zps0d7cbdb1.jpg
Old Apr 19, 2014 | 08:29 AM
  #643
ericjansen's Avatar
Default Cleaned the leather
Cleaned the leather in preparation for some dye-repair.
Thought I bought a clean car, but was shocked to see how much dirt came off.
A must for everyone who has not done this.
Attached Thumbnails What did you do to your X308 Today?-dsc01375_zps2427ac42.jpg   What did you do to your X308 Today?-dsc01384_zps0acfa1cb.jpg   What did you do to your X308 Today?-dsc01378_zps6324ef34.jpg
Old Apr 19, 2014 | 01:26 PM
  #644
RandyS's Avatar
I believe I need to do that to mine also.
What is the cleanser you are using?
RandyS
2003 XJ8 Vanden Plas
1982 BMW 320i
1977 Chevrolet Silverado Stepside
1983 Porsche 944
1987 Mitsubishi Van
Old Apr 19, 2014 | 10:36 PM
  #645
ragman1171's Avatar
Default AutoTrader
Listed "Hope" on Auto Trader.com today. Chose the highest package that didn't involve using their "help".
Also installed a part that came in about a week ago as I just filled up the tank, I can get the numbers to compare the last MLG to this MPG and see how much bull puckey this module is or if it gives me any gains at all. DVMotorsport DVM-EP93 from eBay. The headline reads "+HP +MPG". Here's the description portion:
Add up to 25-50 Horsepower and 35+ ft/lbs of Torque!
Or Increase Fuel Mileage by 25% or more and reduce emissions!
Works on all Fuel Injected models!
100% Reversible, Will Not Void You Warranty!
Safe, will not hurt your vehicle or electronics!
Smoother Acceleration!
Increased Top Speed ability! (does not remove top speed limiter/governor)
Easy install, can be done in less than 5 minutes
Full installation instructions included + unlimited technical support!
The DVMotorsport Perfomance Module is designed to be adjusted to maximize the power or economy from your vehicles current setup. The Perfomance Module will work with a completely stock vehicle or with modified vehicles. Its easy to install, fully reversible, and in most cases requires no cutting or modification of your vehicle. Each one of our Perfomance Module come with detailed installation instructions.
Have you ever wondered why your car seems so much more powerful when it is cold outside? It is because your computer senses intake temperature through the AIT sensor in the intake. It sends signals to your computer which change fuel mapping and ignition timing based on the outside temperature, and (since it is cold in this example) fuel delivery is increased. When it is hot outside, your fuel and timing change again, and fuel delivery and power is decreased, resulting in a fuel mileage increase.
The Perfomance Module, Once Installed, will give you the control of this fuel/ignition mapping.
The "Full instructions included" consists of a link to generic instructions for most cars. They do say to email them with your car's info and they'll send instructions for your car. So I did. They said to give them 24 to 48 hours to respond do to the number of requests that they get. I received a reply within the hour. When I had if you questions regarding those instructions, I received almost immediate reply. They were very good about ensuring my questions were answered. It was almost 9 p.m. When I finished up, so I thought I would take their advice and leaves the negative battery cable disconnected overnight so that the module could online that sell properly with the engine and vice versa. Plus, if I have to go anywhere I can take the Durango. I will be sure to update tomorrow after I get the battery connected and drive around a little bit to get a feel for it. And after this tank of fuel I will be sure and update any significant or insignificant changes, differences, feelings, anything...
I REALLY do not want to let Hope go, but if I don't find a job very soon I'm going to have to...
Old Apr 19, 2014 | 11:13 PM
  #646
ericjansen's Avatar
Just bought the cheapest one, in this case Good Year Leather Cleaner Liquid.
Easy spray-on, but you will need a medium soft brush to really get the dirt out.
Gentle and slow rotating movements, and regular wiping off with a rag does the trick.
It took me one bottle and two hours to do front and rear.
Attached Thumbnails What did you do to your X308 Today?-dsc01458_zpse39b951d.jpg
Old Apr 19, 2014 | 11:23 PM
  #647
ericjansen's Avatar
Patched up the scuff's on the steering wheel, the driver's seat, and the little scratch here and there.
Used SCUFF leather tough up dye, in Sable and Ivory.
The Sable needed a bit of added gloss (set comes with 3 small bottles for color and gloss correction).
The Ivory was spot on.
The driver's armrest was pretty damaged (wear and several scratches), but came out like new.
Finished all off with Zaino Z-10 "leather in a bottle" conditioner, very very pleased with the results.
Attached Thumbnails What did you do to your X308 Today?-dsc01460_zps44bbfab2.jpg   What did you do to your X308 Today?-dsc01394_zps0a71926d.jpg   What did you do to your X308 Today?-dsc01397_zps4df90755.jpg
Old Apr 21, 2014 | 11:14 AM
  #648
Zorasmiles's Avatar
Beautiful trunk! Nice and clean install. Made waiting worth the wait!
Old Apr 21, 2014 | 11:39 AM
  #649
Zorasmiles's Avatar
Dsnyder knows of my current attempt to rescue and restore my Cat to her former beauty. Cleaning is so very crucial as the previous owner really let her go after the warranty was complete. Here are a few pictures of the armrest before and after to give you an idea of how filthy she was upon pickup. I'm also including the seat backs that I purchased from a wrecker yard that was parting out a VDP. These will be used in my modification/upgrade.
Some of the best advice I've received was from Dsnyder. He told me to start making small steps to keep my positivity up.
Attached Thumbnails What did you do to your X308 Today?-vdpcleanvsdirty.jpeg   What did you do to your X308 Today?-vdpxj8cleanseatbacks.jpg   What did you do to your X308 Today?-xj8dirtyconsole.jpeg   What did you do to your X308 Today?-xj8cleanconsole.jpeg
Old Apr 22, 2014 | 12:46 AM
  #650
ericjansen's Avatar
Wow, must have had some courage to buy such car in the first place.
Nice job, keep it going!
Old Apr 22, 2014 | 01:32 AM
  #651
Stu 1986's Avatar
I need to clean up my leather really, the drivers seat is the dirtiest. It looks like it's odd from the rest of the car. I'll get on to that then get a seat cover for when I'm at work.
Yesterday I was doing some sorting in my garage & my XJ was parked on the ramp between the road & pavement/sidewalk. The neighbours kids were going past on their bikes & were getting too close to my kitty. I lost my nerve & decided to move the car forward some more, lucky I did! I slotted into drive & eased forward about 2 feet then heard a clatter. Looking in my rear view mirror I could see the girl had come off her bike, and if I hadn't moved my car she would've been on the rear deck & the bike would've been on the bumper.
I locked the car with the engine running for a bit so it didn't wash the cylinders, as I walked back onto my drive I gave the parents "the stare of death". I didn't see the kids after that.
Old Apr 22, 2014 | 06:22 AM
  #652
ericjansen's Avatar
Default Just loved them both today ...
Attached Thumbnails What did you do to your X308 Today?-dsc01462_zpsb1984a8e.jpg
Old Apr 22, 2014 | 03:30 PM
  #653
Zorasmiles's Avatar
Yes, it took quite a bit of courage to purchase her!! I looked at the car over and over on Craigslist and couldn't believe the asking price. The seller was asking for entirely too much for the car in it's current state. One owner car with 53k miles on her. My wife gasped as I took her to see it LOL Bargained with the owner knowing that her asking price was for a similar Jag in almost excellent condition. Now I'm slowly tackling "THE MUST DO LONG LIST" of repairs and BODY work.
My wife still hasn't come around and remains in shock but time will tell if I made a great decision or really lost my mind prior to purchasing!
Looks like your Cat filled day was most excellent! Good husband=happy wife=more money to take care of the Cat lol
Old Apr 22, 2014 | 09:10 PM
  #654
ericjansen's Avatar
Got the car with a set of extra rear light units.
Although I am a sucker for originality, I have always liked the slightly tinted lights of Arden.
Decided to give it a go, medium smoke.
Picture shows left one done (actually a bit darker then the picture shows), turned out just decent.
Can always go back to original if desired.
Attached Thumbnails What did you do to your X308 Today?-dsc01471_zps554b0b21.jpg
Old Apr 22, 2014 | 09:22 PM
  #655
WaterDragon's Avatar
Replaced the serpentine tensioner today. Now everything is done: all new hoses, new primary and secondary tensioners, rotors, pads, tires, oil, plugs, water pump, intercooler pump, upgraded sc, etc, etc.
Nothing left to do...but drive her a bit, then put her up for sale soon.
Old Apr 23, 2014 | 07:42 AM
  #656
Probesport's Avatar
Put my new wheels on, after going back and forth on size style, tire, etc I decided on these.
18" Coventry Hornet w/ 255/40 tires - more here
Old Apr 29, 2014 | 03:10 AM
  #657
xjrmageddon's Avatar
Default Well, simple, but...
Finally annoyed by the ever-so-slight pulse on idle, so I went ahead and swapped out the plugs with a fresh set of NGK iridium and gave the old cat a quick oil change.
Smooth as silk now... I love this damn car.
Old Apr 29, 2014 | 03:43 AM
  #658
xjay8's Avatar
Just goes to show man...stroke your ***** the right way and it will reward you ;o]P
Did you replace the air filter?
Old Apr 29, 2014 | 04:15 AM
  #659
King Charles's Avatar
Had fuel filter,rear diff.,wiper,plugs done today , she is humming.
Rear oil was better than anticipated.
Attached Thumbnails What did you do to your X308 Today?-10268124_1491053221108355_1876865639_n.jpg   What did you do to your X308 Today?-10299293_1491059181107759_1024668731_n.jpg
Old Apr 29, 2014 | 11:59 PM
  #660
jagjunky's Avatar
sold one of my jags today......hated to see it go......i have had seven jags over the last 15 or so years....and every time i have to let one go i get the same feeling of loss. the people who present themselves as interested buyers probably think i am nuts.....i spend a lot of time trying to find out why they want to buy the car....have they ever owned a jag before?......will they take care of the car?....etc.....it's almost like i were trying to find a home for my two real cats....buddy and willow......you really can get attached to these cars!
