What do you guys use
Old Oct 11, 2017 | 09:35 PM
Z07Brandon's Avatar
Default What do you guys use
To read real time data from the ECU. Want to know what my actual temps are. Plus, it will be helpful for other things as well.
For my 93 Vette, I use an obd1 bluetooth adapter and an app on my phone. Is there something like this for my 02 XJ? And, I had to get an adx file for my vette, and load it into the app. Would I need to do same for my Jag?
Old Oct 11, 2017 | 09:43 PM
nilanium's Avatar
elm327 bluetooth obdII adapter with the Torque phone app are what a lot of people use. Been meaning to get around to it as well. You shouldn't need to load any settings into it. I'm currently using a Innova 3040 handheld scantool for error codes and some basic livedata readings. If you want to get fancy, you could look at something like AutoEnginuity.
Old Oct 11, 2017 | 09:50 PM
Z07Brandon's Avatar
Thanks dude I think for the meantime, torque app and the adapter will be fine. Cool, about to buy it.
Old Oct 12, 2017 | 12:00 AM
larney's Avatar
That's what I use.
Old Oct 12, 2017 | 12:25 AM
Lady Penelope's Avatar
You can see different brands in use on youtube . Torque doesn't have as good of an example of a video as someone set me the live data graph in a posting on this website to resolve an engine regulation problem . Will have to find it . You have to realize that some values like HP are calculated and not directly measured and can be way off . There gimmicks
Attached Thumbnails What do you guys use-wam1c_usakier7mxb8iz0jxew6dagbox2thiahaoqfhrgbgtzaflh7-hh3r_kgbjkrhi%3Dh900.png
Old Oct 12, 2017 | 01:31 AM
King Charles's Avatar
Bluetooth & Torque Pro app via smartphone.
Old Oct 12, 2017 | 09:22 AM
harvest14's Avatar
I have heard good things about the Torque Pro app everyone is referencing. I have used the Ultra-Gauge Blue for about 3 years now. It gets automatic updates from the manufacturer regularly and I've found it to be very reliable. Just my input...
UltraGauge Blue OBDII Scan tool & Information Center
Old Oct 27, 2017 | 01:15 PM
Z07Brandon's Avatar
The elm obd2 finally came in yesterday. I am able to connect to the car's ECU, but torque pro tells me "no coolant data available" Any ideas on that?
Old Oct 27, 2017 | 04:40 PM
JagV8's Avatar
Some weird software bug in it. The car has it ... as required by law.
Old Oct 27, 2017 | 04:54 PM
Try removing the PID . Cycle ELM327 and App off and then restart then add the PID and see if it takes .
For troubleshooting purposes it is better to use the multiple graph line displays over time line .
Old Oct 27, 2017 | 06:19 PM
Z07Brandon's Avatar
Not to sound dumb. What is the PID?
Old Oct 27, 2017 | 06:40 PM
Nope , Parameter Identifications ( or sensor name with value ) as you construct a graph or dials to observe . I don't have experience with Torque so I can't say how to change that brand's
Command Tables - python-OBD
http://obdcon.sourceforge.net/2010/06/obd-ii-pids/
Old Oct 27, 2017 | 06:50 PM
ericjansen's Avatar
An other Torque Pro user here.
What I like about Torque Pro is the custom dial and background selection.
I made a set up in the same blueish green as the Jaguar dials, with a walnut background, looks nice for those times I have it in a stand on the center console.
Old Oct 27, 2017 | 07:13 PM
Yes ! Eric turned me on to this fine MOD lol !
