what is p1316 code ?
Old Jun 1, 2019 | 06:25 PM
RA110623's Avatar
Banned
Default what is p1316 code ?
I checked my car by one scan tool and got multiple misfiring
and p1316 injector circuit IDM detected what is that code and does cause rough idling or engine vibration?
2002 xj8.
Old Jun 1, 2019 | 08:42 PM
motorcarman's Avatar
P1316
Misfire excess emission
NOTE: This DTC will flag only when
accompanied by an individual
cylinder misfire DTC: P0300 –
P0308.
Old Jun 2, 2019 | 11:06 AM
RA110623's Avatar
Banned
P1316
P0308.
solutions?
Old Jun 2, 2019 | 03:52 PM
Jhartz's Avatar
Fix the misfires. What cylinders? I suspect you still have a problem with the timing: review your work.
Old Jun 2, 2019 | 04:50 PM
Jhartz's Avatar
I really cannot stand PMs. So you checked and your timing is ok. Good. Let everybody know, so you can get advise on other possible issues. Start with looking down in the crankcase to be sure you haven't dropped something. Years ago, a guy had an issue because his rag was left in the head when he buttoned it up, rag got sucked into the engine (left side issue) and clogged the oil pump. So you need to keep looking. Most of us are here to help, only if you share what you have done.
Rant complete!
Old Jun 2, 2019 | 05:31 PM
RA110623's Avatar
Banned
Rant complete!
I have updated that with pictures in my other thread I will not start the car until I get endoscope to check if there's broken plastic I'm sure there's some pieces.
Old Jun 24, 2019 | 05:23 AM
RA110623's Avatar
Banned
I had multiple misfiring and the engine was vibrating and not smooth the obd reader did show misfiring in cylinder number 4 and 6 I replaced the coil number 4 with NGK ignition coil and changed the spark plug in that cylinder too with ngk spark plug for the cylinder number 6 I used eBay ignition coil but the coil boot on the eBay coil was too tight I think it wouldn't fit the plug correctly I removed that tight coil boot and used the coil boot from my old denso coil tightened all the bolts of the coil then start the engine the engine run smooth. btw the coil is 4 pin
Old Feb 27, 2024 | 05:48 PM
Johnnyb60's Avatar
Default what if my P1316 isn't accompanied by individual cyl. info?
P1316
P0308.
what then? Do i just have too cheap a code reader?
Old Feb 27, 2024 | 05:49 PM
Johnnyb60's Avatar
P1316
P0308.
what then? Do i just have too cheap a code reader? O, let me lengthen this by 1 character...
Old Feb 27, 2024 | 08:53 PM
RandyS's Avatar
I guess that depends on whether you are getting the information from it
that you need,
Old Feb 28, 2024 | 09:12 AM
Johnnyb60's Avatar
Oh, I take it back. Upon restarting engine, it came back with, in addition to P1316, also P0301, 302, 303 and 304. Please tell me it's not a skipped timing chain. The tensioners are the upgraded steel ones. We were cruising along at 40 mph w a warm engine when Restricted Performance light came on. No terrible noises and easy enough to drive home 2 miles. But def. misfiring/ running rough at idle.
'00 XJR
Old Feb 28, 2024 | 11:45 AM
Jhartz's Avatar
Look for a broken wire across all right bank cylinders. Then pull the cam cover on the right bank and use a straight edge to check for alignment of the secondary timing chain . . . lots of threads on timing chains . . .
Sort of a shame we never heard what the originator in 2019 found was his cause . . .
Old Feb 28, 2024 | 02:56 PM
Johnnyb60's Avatar
I failed to mention that before the P1316, I got P0172 Bank 1 rich fuel mixture. Can someone please shine the Motorcarman light into the Gotham night sky...
Old Feb 29, 2024 | 11:04 AM
Johnnyb60's Avatar
also curious if you'd actually be able to eyeball it if the chain had just skipped one tooth? It's still on the sprocket isn't it?
Old Feb 29, 2024 | 02:50 PM
Jhartz's Avatar
That's why you turn the engine until you can put a straight edge across the front: again, look for threads on secondary timing chain to see a picture (better than a thousand . . . ) of what I mean . . .
Old Mar 3, 2024 | 11:29 AM
Johnnyb60's Avatar
O i get it, straight edge across cam lobes. Luckily that won't be necessary. I cleaned the MAF sensor, charged the battery for a day, wiggled some ground wires, pulled one coil and plug on R bank (looked fine), maintained a casual I-don't-really-care air – and running fine again now on all 8 cylinders, no codes. Typical.
Old Dec 25, 2024 | 02:19 PM
SLT's Avatar
SLT
Default 2005 S type 4.2L error codes
My check engine light came on. I read the error codes and they are P0300, P0301, P0302, P0303, P0304, P0305, P1313, P1316, P1000. Even though the error codes are for misfiring on cylinders 1 through 5, the car runs smooth. A mechanic suggested that I change all 8 spark plugs and ignition coils, so he changed them. The error codes came back a week later with additional codes P0306 and P0307. What should I do next? The car still runs smooth and has 112000 miles.
Old Dec 26, 2024 | 02:44 PM
Jhartz's Avatar
You are in the X308 (4.0L) V 8. Move your question to the S type forum.
GoobeGustafson
Jun 20, 2017 10:58 PM
beady
Mar 22, 2015 01:33 PM
Rhett
Jan 6, 2015 12:07 AM
djpxk8
Oct 25, 2013 08:27 AM
phaelax
Apr 26, 2013 11:49 AM
