Where is COIL C located?
Old Apr 14, 2012 | 02:35 PM
newuser's Avatar
Default Where is COIL C located?
I've searched and I looked at the cylinder # diagram. I know the cylinders are numbered 1-4 on both banks. But the codes I got are P0303 (cylinder 3) and P0353 (coil C). My question is what side of the engine is that? The codes I got did not say bank A or B. Thanks for any help.
Old Apr 14, 2012 | 02:50 PM
It's 3 take a look at the pdf.
File Type: pdf
Old Apr 14, 2012 | 04:59 PM
avt007's Avatar
Thanks for posting that Norri, but it's not particularly helpful, is it? For my car it lists two different numbering systems.
Old Apr 14, 2012 | 05:22 PM
It does, but they are both the same aren't they? It just has two different ways of designating them.
I didn't just make it up.
Old Apr 15, 2012 | 07:19 AM
jimlombardi's Avatar
Hi newuser
Here is the cylinder numbering chart that testpoint posted in another thread (I have it on my PC):
I extracted the Alternate V8 Cylinder Numbering information from Norri's Post (I rotated the image 180 degrees to be able to make the comparison easier the view):
I tried to compare this diagram on left with the other one Norri posted (Alternate V8). From Allternate V8: Cylinder numbering From Front on Bank 1 is 1, 2, 3, 4 ; on Bank 2 is 5, 6, 7, 8.
Firing Order is Bank 1 Cylinder 1 (1), Bank 2 Cylinder 1 (5), Bank 1 Cylinder 4 (4), Bank 1 Cylinder 2 (2), Bank 2 Cylinder 2 (6), Bank 1 Cylinder 3 (3), Bank 2 Cylinder 3 (7), Bank2 Cylinder 4 (8).
This gives you firing order 1 : 5 : 4 : 2 : 6 : 3 : 7 : 8
Firing order on Norri Posted is 1-5-4-2-6-3-7-8
Where is COIL C located?-v8-cylinder-numbering.jpg Where is COIL C located?-alternate-v8-cylinder-numbering.jpg
The image and the attachment are the same diagram (you can right mouse click and use save as option - to save it on your PC)
Jim Lombardi
Attached Thumbnails Where is COIL C located?-alternate-v8-cylinder-numbering-1.jpg
Old Apr 15, 2012 | 02:14 PM
newuser's Avatar
Originally Posted by jimlombardi
Hi newuser
I extracted the Alternate V8 Cylinder Numbering information from Norri's Post:
Attachment 18597 Attachment 18607
Jim Lombardi
Thanks so much, Jim. I got it running good again after replacing the coil. Everyone here have been helpful and i appreciate that.
Last edited by Norri; Apr 15, 2012 at 02:59 PM. Reason: edited images to maintain page width
Old Apr 15, 2012 | 02:45 PM
Which one did you replace?
Old Apr 15, 2012 | 08:17 PM
newuser's Avatar
#3. The 2nd one from the firewall on the passenger side. Got it from Autozone for $113 with a 2 year warranty. Its the exact same one OEM made by Denso.
kthrash
Feb 25, 2019 10:20 AM
jagtoes
Apr 22, 2016 07:37 AM
Bcrary3
Sep 27, 2015 12:21 PM
reb1999
Sep 26, 2015 08:41 AM
vacolorito
Sep 25, 2015 09:29 AM
