Where To Tap Vac Line For Boost Gauge?
Old May 25, 2016 | 03:43 PM
xjrjag's Avatar
Default Where To Tap Vac Line For Boost Gauge?
Going to be installing a boost gauge into my XJR and was wondering where the best place is to tap for the vac line? On a few of my older turbo cars, I ran directly off of the intake manifold or fuel pressure solenoid, where available. Not 100% sure where I should tap on this vehicle though.
Old May 26, 2016 | 06:58 AM
Highhorse's Avatar
You may want to ask Waterdragon, he's done some attachments and mods. Perceptively I agree with the takeoff from the intake, but I'd want to check with someone who's done it.
Old May 26, 2016 | 12:55 PM
cybercg's Avatar
Default Inquiring Minds Want to Know
I would like to know where you will mount the vac gauge. Pics would be great!
Old May 26, 2016 | 01:11 PM
xjrjag's Avatar
I already made my pod and everything, just waiting on the wiring end until i figure out where to tap the line.
But I modified my drivers side defrost vent to hold the boost gauge and it looks fairly stock after I painted it.
Old May 26, 2016 | 04:29 PM
Highhorse's Avatar
Here's a link to one of Waterdragon's threads, he has a new car, but posted some of his old stuff....https://www.jaguarforums.com/forum/x...ue-vdp-162181/
Old May 28, 2016 | 08:53 PM
greverrr's Avatar
This thread should help you if you haven't found out already Specifically post 4+5.
https://www.jaguarforums.com/forum/x...install-70090/
Old May 31, 2016 | 02:21 AM
xjrjag's Avatar
Completed the install of the boost gauge. There is a PERFECT spot to tap the vac line. It was mentioned in a previous thread that there is a vac line coming off of the "V8 cover" and it is right there on the passengers side. I traced that line and it actually has a T fitting on it. That T fitting goes to the FPR and then the other side actually has a vac cap on it. I removed the cap and put the tubing that came with the boost gauge there. The rest was a matter of routing the line, all the wiring to the gauge and finding a 12v key on source.
Old Nov 5, 2023 | 01:56 PM
booshiba's Avatar
Are we talking about left hand or right hand drive cars? I can't find a single vacuum like on my U.S. spec passenger side where everyone is talking about.
NVM, I found it 😌
mcphill
Nov 26, 2025 03:07 PM
Oxidizer2k
Jan 2, 2021 10:38 PM
carlorner
Jun 8, 2011 05:05 PM
nglshmn
Oct 4, 2009 06:13 PM
