X308 stability control/failsafe mode
Old Jun 7, 2023 | 02:08 PM
Topaz 99's Avatar
Default X308 stability control/failsafe mode
1999 XJ8 L intermittently getting stability control/failsafe mode. Happening at low speed, usually after a no problems 1st drive of the day. Has been going away after shutting down and restarting. It has now gotten worse and is immediately happening upon start up. Took to mechanic and no codes are being shown. Battery is good. I've read just about every thread I could find on the subject and there seems to be alot of theories. Was just wondering if the fact that is now happening upon start up means anything?
Old Jun 7, 2023 | 04:26 PM
motorcarman's Avatar
There are DTCs, maybe NOT in the ECM but a module on the CAN bus has info that a regular 'scan-tool' will not read.
You need a COMPLETE scan of ALL modules on the CAN bus and the SCP network.
I use WDS and IDS but there are other tools that can read all modules.
Snackalac
Nov 10, 2022 08:24 AM
santapool
Apr 29, 2017 09:32 AM
smtguy
May 14, 2013 08:12 AM
Jag u r
Nov 8, 2012 01:22 PM
djsomebody
Jul 18, 2011 08:16 PM
