X308 subwoofer
Old Sep 24, 2017 | 12:30 PM
RA012623's Avatar
Banned
Default X308 subwoofer
Can anyone point me in the direction to finding a rear parcel shelf mounted subwoofer for my beautiful 2002 Carnival Red Vanden Plas? Other than auto recyclers, I've exhausted my options in finding one on the interwebs. Thanks in advance.
Old Sep 24, 2017 | 12:58 PM
Lady Penelope's Avatar
Is it say a 6 X 9 or similar in size to mount correctly and is it a dual cone ?
You can repair the existing speaker by replacing the speaker cone surround foam ( not the mounting foam) which rots and goes bad in the following vendors video and see the link to there website for more info . To order the replacement foam you would have to remove the speaker and get the specific cone edge and speaker frame dimensions other then say the generic 6 X 9 . Below is a dimension pic for a X300 non - premium door round speaker ( yours may be different on the X308 ) as a gluing surface overlap is important . You might be able to order a couple of different sizes in a estimated range and return what you don't use as this would negate the need the remove and replace the parcel shelf twice .
https://www.jaguarclassicparts.com/u...premium-system
Old Sep 24, 2017 | 07:38 PM
motorcarman's Avatar
I have repaired 3 or 4 dual coil 6 x 9 X300 and X308 subwoofers in the last year.
The Harmon Kardon and Alpine use the same repair kit. I use Speaker Works (like Lady Penelope) but there are others like simply speakers.com etc.
6" x 9" Angled Speaker Repair Kit For Replacing Foam Surrounds
I also repair the 6 1/2" door loudspeakers with the SWK65
6 1/2" Speaker Repair Kit For Replacing Foam Surrounds - Advent, Bang & Olufsen, Boston Acoustics, JBL, Heathkit, Polydax, Paradigm
bob
Old Sep 24, 2017 | 11:13 PM
Col. Sandurz's Avatar
bob
I repaired a couple as well. Hardest part is removing rear shelf without crushing the edges.
I've looked multiple times for new speakers and every time I have just repaired. Very easy for almost anyone.
Follow links above.
Old Sep 24, 2017 | 11:52 PM
Note that the door speaker in the pic example is for the original equipment non-premium system X300 . The premium system speaker size may be different as well as the difference between the X300 and X308
Old Sep 25, 2017 | 04:00 AM
Stu 1986's Avatar
Do you already have a Subwoofer? You don't mention if you do or not and adding one to the system is not just a simple case of plug in and play. However I'll assume for now you do have one.
My rear sub was damaged so I replaced it, for now, with a 6x9 high specification 3 way speaker and plugged in just one of the two plugs. It does work well but ideally you'd want the original one working correctly. So repair, something I'm going to attempt on my old one, is your best option.
Old Sep 25, 2017 | 09:14 AM
The PHILIPS and ALPINE are both the same as far as the repair kit is concerned.
It's been a while since I looked at the X300 door speakers. The Premium Sound in the X300 is Harmon Kardon.
bob
Old Sep 25, 2017 | 11:43 AM
RA012623's Avatar
Banned
Thanks to you all.
I do have the original subwoofer but as you've all correctly identified, all the foam is gone. The paper cone is actually separated completely from the foam surrounds.
Stu, which speaker did you use to replace the original subwoofer? As you know, the depth of the original speaker is very shallow. A replacement would have to be quite skinny.
Thanks again all.
Rob
Old Sep 25, 2017 | 02:59 PM
CharlzO's Avatar
Honestly, you'll be farther ahead to repair the one that's there, it's relatively inexpensive, it's matched to the original system, and you have to remove the parcel shelf either way. As you've seen there are very few shallow mount 6x9s to begin with, and you're going to use a full range speaker that will get filtered out (thankfully). I repaired mine, and the sound is rather impressive for what it is, especially setting to the FRONT sound stage setting. Sure you won't get real deep bass but it's certainly better than a lot of stock systems I've heard.
It really only took overnight to fix mine. It was a 5 minute job to glue the new foam in. Took it out one night at home, pulled the speaker and glued it. Next morning, put it back in, and away ya go.
Old Sep 26, 2017 | 09:29 AM
RA012623's Avatar
Banned
Thanks CharlzO. I have the speak out and now I guess I'm in the speaker repair business;o)
Old Sep 26, 2017 | 06:55 PM
rocklandjag's Avatar
The repair is really simple. Did mine a while back. Do a search and you will find my post
Old Sep 27, 2017 | 03:58 AM
Stu 1986's Avatar
I used a Pioneer 6x9 which was rated as being quite powerful and shallow. I did have to make an MDF Mounting ring for it though, but it doesn't foul on the speaker grill. But as I said this was always going to be a temporary fix as I would like the original one back in.
It's a shame there's no way to replace the cardboard cone on the alpine with a plastic one, that'd be good. I mentioned this to my friend and he queried whether it would be possible to coat the cardboard in brush on resin to imitate plastic, but I'm not sure if this would work.
Old Sep 29, 2017 | 07:09 PM
coastaljag98's Avatar
I actually removed mine and then with the open hole to the trunk, put the grill back on to cover hole and then installed an amplified Infinity sub and it made it soooo much nicer. There is Bass now!
Old Sep 29, 2017 | 08:26 PM
It would effect the free movement of the cone / sound
Old Sep 30, 2017 | 02:13 PM
RA012623's Avatar
Banned
Hi coastaljag98. When you installed your sub, how did you connect the dual voice coil connectors to your amp? I'd like to use my existing radio head controls for the subwoofer and to do that, I'll need to use the two existing connectors that would normally be connected to the stock subwoofer.
Old Sep 30, 2017 | 04:08 PM
CharlzO's Avatar
Many people that do replace it with a stock single coil 6x9 just use one side of the factory harness. The sub frequencies aren't usually out of balance Left-to-Right in music, i.e. you don't usually hear the bass from only one channel, like you do sometimes with vocals and mids - the bass is present in both channels pretty much all the time. It does work, though not optimally, but with a serious lack of shallow mount, dual voice-coil 6x9 woofer speakers on the market, it's one option that has been used.
Old Oct 6, 2017 | 10:47 PM
I just removed the busted factory sub and left the hole so that the new powered sub in the trunk would come through (sound). The hole acts as an air port so it sounds better. Trunk also gets a lil AC too. ☺️
