XJ8 door card casing clip -Wrong size!
Old May 3, 2026 | 09:46 PM
Iconoclast's Avatar
Default XJ8 door card casing clip -Wrong size!
I was troubleshooting the door release last year & when I replaced the driver door card/panel I broke the clip on the lower left corner (as I face the panel)
I searched & found a replacement.
It came in a green colored plastic pouch.
Has a barcode and it says: "Jaguar door panel casing clip XJ8 98–03”
Also has the following model number: “KTD300002GEN.
I have procrastinated because I didn't wanna take the whole door card off again. Today I decided to see if I could replace it by just pulling the loose lower outside corner and the answer is yes… Almost..
My replacement clip is significantly smaller than my old damaged one!
I used my digital caliper and measured my new clip and the circular top is 19.4 mm O.D..
My old semi oval shaped bad clip is 21.4 mm wide & 22.7 mm long O.D.
The slot on my new clip is much too small to slide onto the white, round, plastic, ‘button’ piece on the door. I tried forcing it but not even close.
Searching I see only clips that look like the new one I bought that is too small.
Found an eBay listing for 30X Door Panel Fastener Clip Stud Fits For Jaguar Xj8 XJR 1998 1999 2000-2003
But it shows top = 13.4 mm O.D. Even smaller than my new clip!
I assumed all the door clips around the edges of the door card were the same size. Only the huge one in the center was much larger & completely different.
Any ideas?
Thanks!
Steve
Old May 4, 2026 | 09:55 AM
clubairth1's Avatar
Community Influencer
Those are a 2 part clip. The pin part you show fits into a plastic part in the door.
But I see several options? I don't have your last 6 digits of the cars VIN but I think they did not change over time?
Maybe you need the KTD300003 part number since the KTD300002 is not matching your car?
I don't know what "other" means either?
Old May 5, 2026 | 01:41 AM
Iconoclast's Avatar
I know all the clips are basically 2 parts
In your 1st image I am talking only about part number 4.
Part 5 is on the door frame, not the door card/panel.
I have no doubt that 4 will fit into 5 on my car.
The issue is how to secure part 4 to my door card.
The top or ‘head’ of part 4 seen on the L in your image, must securely attach to a white plastic ‘button’ on my door card.
The slot in my part 4 is much too small.
Old May 5, 2026 | 01:51 AM
Iconoclast's Avatar
Found eBay & it looks like my old part!
You may be onto the solution!
I will try to find other options for KTD300003 in case it still does not fit or I have more than the single broken clip.
https://www.ebay.com/itm/12766745991...MDPDAK5FB41MWT
Old May 5, 2026 | 01:55 AM
Iconoclast's Avatar
But here is another listing (#KTD300003) where the photo is the same too small part
https://welshent.com/Bolts-Fasteners...sing-Door-Clip
Old May 5, 2026 | 09:04 AM
clubairth1's Avatar
Yes that was my point. I can't explain what "other" means in the parts listing. But it would be worth a try to see if that other number does work or not.
They are close so hard to tell what will work without having it in your hand.
Old May 5, 2026 | 11:27 AM
Jhartz's Avatar
Part # 4, the male, is held in cut-out slots in the door card; you fit 4s to the door card, align it to #5s, punch it home.
Old May 8, 2026 | 05:54 AM
Iconoclast's Avatar
I know.
My new part #4 & all the ones linked are too small. Cannot find a part #4 like my old damaged one.
I've seem measurements of < 19.4 for male clips for sale on ebay
PCjags
Jan 4, 2026 03:50 PM
Silverjag0
Dec 25, 2024 10:45 AM
mghirsch
Nov 20, 2024 11:17 AM
SparkyGage
Jun 23, 2015 11:13 AM
Carthage4404
Jan 28, 2015 08:01 PM
