XJ8 Wheel Size Maximum
Old May 24, 2019 | 05:33 PM
Jagger98's Avatar
Default XJ8 Wheel Size Maximum
Sorry for another post, thinking of enhancements to the car, wheels size, these seem to be the max!
4.0i XJR Current Spec. Rim: 10j x 21 ET20 tyres - 285/25ZR21 95Z
Will the XJR fit my XJ8 Ok, and how much space at this size is left between
tyre and suspension strut and tyre and wing arch (fender for our American brothers&sisters)
would 21” 10.5J fit, for the rear ?
jagger98
Old May 24, 2019 | 09:00 PM
Ungn's Avatar
What year XJR is that? 255 appears to be the largest tire width on an X308 from the factory, 275's seems doable with some fender rolling and seam cutting. Unless the car is jack up in the air, 285 might be 10mm too much.
XJ8 rear fenderwells can fit larger tires by rolling the wheel arch and cutting away some of the body weld seam that protrudes about 1" into the fender well. I doubt any tire larger than 255 will fit without doing that, unless it sticks out past the fender lip.
Old May 24, 2019 | 09:01 PM
King Charles's Avatar
Do a forum search, this has been covered in depth before.
Old May 25, 2019 | 05:36 AM
ericjansen's Avatar
285/25R21 has a outside diameter of some 675mm (26.6"), which is in line with other sizes used by Jaguar on the x308.
For the rear, the tire width should fit with the proper offset of the rim, ET20 as you mentioned should be OK.
You will need to remove the rear bump stop, maybe you can use the later X100 one, or cut the old version in half.
It will be very very close to the fender, and depending a bit of the brand of tires, as they are all different.
For the front though, there is noooo way those will fit without damaging the fender and linings.
AND REMEMBER, the x308 (and the x100 2 door) were the last models using 5x120.65mm bolt pattern, wheels from later models don't fit!
Old May 26, 2019 | 04:43 AM
xjack's Avatar
Do you mean something like that ?:
Old May 26, 2019 | 03:32 PM
Jagger98's Avatar
Well, Ugly man..........., we don’t do tractors in Jags, ours are more class, see below, 21”
Jagger98
Old May 26, 2019 | 04:13 PM
Ungn's Avatar
Jagger98
Those wheels are the wrong bolt pattern and won't bolt on to an X308
Old May 26, 2019 | 04:40 PM
Jagger98's Avatar
I know, I was making the point that 21” would still look good, to me anyway,
just prompted another question, can I fit the later 108 PCD hub and strut to the XJ8.........
jagger98
Old May 26, 2019 | 06:12 PM
Addicted2boost's Avatar
I believe these roulette wheels are about as bold as you can get without lifting the car like that X300 pictured above.
Old May 26, 2019 | 06:46 PM
ericjansen's Avatar
You know you will get some flack considering 21" ....
I myself think they are way too big for the x308 design, but tried to answer your questions honestly.
To each there own is what you say there, right?
And no to the above question too, will not fit, totally different design.
Old May 27, 2019 | 03:26 AM
xjack's Avatar
Just trolling around, me too i'm wonder what can be used on x308 instead of stock alloys
Old May 28, 2019 | 02:33 AM
Jagger98's Avatar
Just read somewhere on the forum that the XK up to 2007 has the XJ8 bolt pattern, can anyone confirm this, it opens up the choice of wheels that can be used.
Old May 28, 2019 | 10:02 PM
ericjansen's Avatar
Well, in stead of just posting, you might want to read the replies as well .... it was mentioned above.
Old May 28, 2019 | 10:13 PM
Drove a 2001 LWB W/ 20 inch DUB Bellagios, it handled like a shopping cart lol.
Old May 28, 2019 | 10:20 PM
Ungn's Avatar
Xk8's and XKR's up to '06. '07 XK's are different
Old May 29, 2019 | 02:01 AM
Jagger98's Avatar
Great, thank you for the confirmation, appreciate it.
Old Jun 4, 2019 | 06:07 PM
Jagger98's Avatar
Great thread here on Wheels and Sizes
https://www.jaguarforums.com/forum/x...27/#post910399
bob5tafford
Mar 12, 2015 04:33 PM
fatherrussia
Feb 9, 2015 05:43 AM
Rich.
Mar 25, 2012 01:42 PM
Craig Schmidt
Oct 26, 2011 05:54 PM
