XJ8 X308 1998 - Instrument Cluster lights
Old Jul 13, 2015 | 05:53 AM
pekkas-1's Avatar
Default XJ8 X308 1998 - Instrument Cluster lights
The instrument cluster is not illuminated indicator light (green). I've been using the "AUTO" car position and the lights come on yes when it is dark, but when the lights come on it still does not light up on the instrument panel lights. What could be the problem? In fact, I suspect that the fault could be "flasherswitch", which is that "Trip switch " and even that did not work, I think..
Old Jul 13, 2015 | 08:22 PM
andrew lowe's Avatar
Try turning the panel light dimmer switch to the opposite of what it is now set at.
Old Jul 14, 2015 | 02:00 AM
pekkas-1's Avatar
Okey I trying.
Old Jul 14, 2015 | 02:19 AM
If that isn't the cause then check the bulbs.
The Instrument Pack has to be removed to access the bulbs.
Attached Thumbnails XJ8 X308 1998 - Instrument Cluster lights-x308-instrument-pack.jpg
Old Jul 14, 2015 | 03:16 AM
pekkas-1's Avatar
I checked yesterday those instrument panel lights and three of the bulb was broken, but it's indicator light (green) does not light up in the right gauge, which knows that the headlights are turned on. That`s lights I mean.
I mean this bulbs. With a picture of the instrument cluster. Picture 4
http://www.pistonheads.com/gassing/t...41620&d=0&nmt=
Is this indication lights bulb, which can be changed??
Or is it the fault the indicator switch?
I am afraid a little bit to take the steering wheel off, due to airbag!
Old Jul 19, 2015 | 12:03 PM
pekkas-1's Avatar
This kind of lamp is not working ( headlamp ) --> http://media.clusterrepairsuk.co.uk/...2210_big.pjpeg
What could be fault?
Old Jul 20, 2015 | 06:00 AM
Sean B's Avatar
l.e.d failure, there's a number of them on the instrument pack that can fail over time, they can be replaced but it's best left to a specialist, they're suface mount (soldered onto the board) not screw-in illumination bulbs.
Old Jul 21, 2015 | 11:28 AM
pekkas-1's Avatar
Thank you so much information. I'm trying to find someone to see if the meter repair shop could fix that problem. Thank`s !!
SteveSheldon
UK & Eire
505
Jul 14, 2016 04:48 AM
redrover41
23
Sep 25, 2015 01:33 PM
carcycle
Sep 7, 2015 10:22 AM
martybmw
Sep 4, 2015 11:05 PM
AL NZ
Sep 4, 2015 08:39 PM
