XJR Dashboard lights go out when external lights switched on.
Old Dec 20, 2012 | 09:07 AM
Peterch's Avatar
Unhappy XJR Dashboard lights go out when external lights switched on.
All my interior dashboard lights go out when I switch on the exterior lights. (2001 XJR)
I have had the switch stalk unit replaced that fixed the problem for one day then they went out again next day.
Any ideas??????
Old Dec 20, 2012 | 02:48 PM
Red October's Avatar
It might be the dimmer control on the steering column-it only works when the exterior lights are switched on. Sometimes just repeatedly rotating the control knob back & forth quite quickly can clean it up again...
Old Dec 21, 2012 | 04:27 AM
Peterch's Avatar
Smile
Cheers, I'll try that
Old Dec 21, 2012 | 06:18 AM
plums's Avatar
You can also turn the dimmer switch beyond the click stop to the "over ride" position. Full bright.
Old Dec 21, 2012 | 01:43 PM
jimlombardi's Avatar
Turn the Dimmer Switch anti-clockwise fully (Override position).
Jim Lombardi
Old Jan 7, 2013 | 05:30 AM
Peterch's Avatar
Default Dashboard lights
That didn't work.
It is only the instrument lights that go out.
The computer, radio and heater display lights stay on.
Old Jan 26, 2013 | 01:35 PM
raugaJ's Avatar
Default I just had this problem
Just like your problem. I found that it was just a bad fuse in the box under the seat. Cheap fix!
Do you have a fuse box map for your Jag?
Hope this helps!
Old Feb 5, 2013 | 09:33 AM
Peterch's Avatar
Unhappy
Not a fuse, only the speedo, rev counter and fuel / water temp guage lights go out.......
Old Mar 10, 2013 | 12:54 PM
theonlyhadrien's Avatar
Default same problem
I'm having the same problem with my Jag. I took it to get the new stereo installed and ever since then, the dashboard and other interior lights won't turn on unless i have it switched to very bottom setting, and when i use that setting, the headlights are off, and on top of that, the rest of the interior won't light up even when i have it on that setting.
I'm contacting the guy who works on Jags that i know. I'll let you guys know if he is able to fix it/how he fixed it.
-Hadrien
Old Mar 11, 2013 | 04:38 AM
Peterch's Avatar
Changed the dimmer switch as well, no luck.. still the same
no instruments lights when exterior lights on
It's strange that the intruments lights worked for 1 day after I changed the lighting stalk..
Jpav27
Jul 31, 2022 06:43 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
XFR_Gold
Sep 2, 2015 12:24 PM
