Yet another interior illumination question,
Old Apr 6, 2019 | 06:21 AM
King Charles's Avatar
Default Yet another interior illumination question,
Are the fan,lock/key & Valet buttons(see red marks) supposed to be back lit ?!
Edit :
Never mind I found my answer(search was malfunctioning earlier) wow I'm missing more than I thought lol. Now I just need the bulb #s as I don't want LEDs.
https://www.jaguarforums.com/forum/x...e-light-40725/
Old Apr 6, 2019 | 06:57 AM
My own previous post but I can't figure out which ones I need as my fan,valet,unlock & temp up & down should all be the same color yet I see green,blue & clear listed as console button bulbs lol ?!
Originally Posted by King Charles
Clock Bulb
LNC5180AA
or
EiKO Clear 2721MF Incandescent Bulb(cheaper & readily available OEM replacement just reuse the blue cap/filter)
Dash/Instrument Cluster
LJA4390AA
Door Switch Packs
Passenger 1 per door : DBC6244
Driver 2 of each : DBC6244 & LNA518CA
Warning Light
LJA4390BA
Console Switch Bulb Blue
LNA5180DA
Console Switch Bulb Clear
LNA5180EA
Courtesy Lamp
DBC11381
Trunk Lamp
LNA5180AA
Puddle Lamp
XR811819 or DBC11381
Glovebox
DBC11380
Visor Bulb
LJA5180BA
A/C LCD
JLM11965
Low Blue
JLM20308
Low Green
JLM20309
Old Apr 6, 2019 | 09:10 AM
Ok making progress but JagBit's is stumped as well. I've deciphered from looking @ the back of one on ebay. I need the 65 MA Blue & Clear bulbs. But still zero ideas as to what the fan knob buttons & temp up & down require.
I'm going to buy a damaged one off Ebay for $15 & disect for bulb info. I will finally document this info. Jagbits,SNG all drawing the same blanks as me. $15 scrapper sure beats $120 in bulbs I may not need lol.
Old Apr 6, 2019 | 10:27 AM
Carnival Kid's Avatar
KC, I am preparing to replace my temp up-down bulbs (one has finally failed altogether on me) and from the research I've done the replacement bulbs are JLM11965.
This is from the youtube vid......................
Old Apr 6, 2019 | 11:25 AM
jagbits's Avatar
Former Sponsor
Jagbits isn't stumped lol I emailed you the parts diagram, quantities and part numbers LOL!!!
Old Apr 6, 2019 | 07:29 PM
There was no diagram attached only this "I attached the 3 different bulbs in that panel with the quantities of each in that panel. 2 LCD bulbs, 7 low voltage bulbs that are blue and 2 that are green this is all the information that I have.". Could you upload the diagram here ?! It would surely come in handy now & in the future. Thanks
That leaves me a choice between 4 bulbs lol, No worries I ordered a donor panel, seriously over engineered though.
The video is for the temp display back light, I'm looking for the actual temp up/down arrow bulbs.
I need these.
Old Apr 6, 2019 | 08:22 PM
jagbits's Avatar
Former Sponsor
Default diagram as requested
Old Apr 6, 2019 | 10:10 PM
Ah, didn't realize that.
Old Apr 6, 2019 | 11:10 PM
Yeah no problem I solved that bulb riddle last year lol. Hard to believe someone thought it was a good idea to have so many buttons w/ varying bulbs. I don't want LEDs as I find them too bright for this application. Even with the donor on it's way I'm already seeing there's 2 blue bulbs that look the same but have different part # & it's not the superseded replaced bulb scenario as they are both still listed in the same panel, just not by exact location lol.
Edit :
One thing's for certain when my donor panel arrives I will take pics of it dismantled & document the bulbs needed. The interior bulb schematics on these cars is convoluted & spread about the web, then you have the bulb # is now superseded by bulb # scenario, it makes a should be easy task a long drawn chore. A thread w/ everything clearly stated would have saved me a few grey hairs lol.
Even w/ the diagram for the bottom part(without Valet,Heated seats etc.) there's 14 lights the diagram accounts for 11.
Old Apr 7, 2019 | 06:01 AM
One thing's for certain when my donor panel arrives I will take pics of it dismantled & document the bulbs needed. .
That would be an EXCELLENT forum sticky!
Armstrong
May 2, 2017 07:19 AM
prettybluefin
Mar 23, 2017 05:47 PM
motorcarsrandy
Feb 11, 2014 06:45 AM
Abe Blumpkin
Sep 10, 2011 09:11 AM
mbalce
Oct 15, 2009 10:15 PM
