XJ40 ( XJ81 ) 1986 - 1994
6.0 V12 Accelerator Cable Adjustment
Old Nov 12, 2014 | 07:23 PM
Rok_Dr's Avatar
Default 6.0 V12 Accelerator Cable Adjustment
Hi All
Lady Penelope has always had a bit of hesitation between putting my foot on the accelerator and starting to move. Over the weekend I had a poke under the bonnet and found that there was a bit of slack in the accelerator cable with a 2.5mm gap between the accelerator cam and the throttle linkage plate.
I tightened the gap up to 0.5mm using the barrel cable adjuster, which has significantly improved her response. The attached pic illustrates.
Is 0.5mm too tight/loose and if so what would people recommend as an appropriate gap?
Steve
Attached Thumbnails 6.0 V12 Accelerator Cable Adjustment-dsc00521-2-large-.jpg
Old Nov 13, 2014 | 12:39 PM
Don B's Avatar
Hi Steve,
I adjusted the throttle cable on our '93 while the engine was running so I could eliminate as much slack as possible without raising the idle rpm. I listened for an increase in rpm and checked the tachometer to confirm. Here's a link to photos of the job on our N/A 6-cylinder:
Welcome to Jag-lovers - Members Photo Viewing Page
I agree that removing the slack produces a significant improvement in engine response to pedal input.
Cheers,
Don
Old Nov 13, 2014 | 10:31 PM
Rok_Dr's Avatar
Many thanks Don
That's a good writeup.
Steve
1100me
Jul 24, 2023 06:10 PM
Gus
Oct 15, 2019 12:29 PM
Richard_gib
Sep 12, 2015 07:08 PM
AtholC
Sep 9, 2015 09:07 PM
1100me
Sep 7, 2015 06:26 AM
