XJ40 ( XJ81 ) 1986 - 1994
Check Engine light is on and VCM doesn't give any info
Old Feb 26, 2012 | 04:56 PM
Steve W's Avatar
Default Check Engine light is on and VCM doesn't give any info
I almost thought it wasn't going to get home the way it almost stalled at the red light. Any ideas???
Old Feb 26, 2012 | 05:00 PM
mrtalkradio's Avatar
Disregard if you already know this. VCM with a check engine light won't read anything while the car is running. The key needs to be in position 2 to get the code.
Old Feb 26, 2012 | 05:09 PM
Steve W's Avatar
It says Fuel 14/Fail 14. Is that a fuse or is it that the fuel pump needs to be replaced?
Old Feb 26, 2012 | 07:00 PM
robhair's Avatar
could be the fuel relay also
Old Feb 26, 2012 | 08:29 PM
motorcarman's Avatar
Does anyone read the sticky section for the S91_AJ6 Engine Management Guide I uploaded???????
That document will tell you more than you need to know about the engine management.
FF14 COOLANT TEMP SENSOR AND CIRCUIT.
bob gauff
Old Feb 27, 2012 | 04:11 AM
Cadillac's Avatar
Thanks guys, mine is not giving out any code either . I didn't know key II was the trick lol
Old Feb 27, 2012 | 04:13 AM
Yes sir! I printed it out months ago, its hanging on a clip board in the garage. It's priceless.
Old Feb 27, 2012 | 08:12 AM
Steve W's Avatar
Is it safe to at least drive it to the service place? It's about 15 miles away.
Old Feb 27, 2012 | 12:07 PM
Steve W's Avatar
It was the Thermostat
BrentGardner
29
Dec 16, 2024 12:13 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
big d
Sep 3, 2015 07:37 PM
tonydbaker
Aug 30, 2015 11:02 PM
SingBlueSilver
Aug 27, 2015 02:20 PM
