XJ40 ( XJ81 ) 1986 - 1994
Door lock gremlins...
Old Sep 13, 2007 | 09:29 AM
XJ40ish's Avatar
Default Door lock gremlins...
This morning I unlocked my XJ, only to have it immediately relock the door, etc. Each time I unlocked he car it relocked. Manualy pulling the drivers side lock knob met with the same results even with the key in the ignition, and running? When I used the passenger lock to unlock the car it unlocked normaly? When I drove the car to work, I parked it and checked the lock operation and everything works fine?? My concern is there may be a time when the car locks when running and I won't be able to get in. Has anyone run across this and what is the sugested fix? Ken? you out there?
Old Sep 13, 2007 | 10:14 AM
Cadillac's Avatar
Default RE: Door lock gremlins...
Do you have an aftermarket alarm ? If it fails it might happen anything
Old Sep 13, 2007 | 10:28 AM
ken@britishparts.com's Avatar
I would suspect the driver's side actuator is up to no good. It's a master for the rest of the system, so if it malfunctions and locks it tells all the other doors to lock as well. It's where I would start.
Old Sep 13, 2007 | 12:28 PM
estunum's Avatar
Speaking of door locks, I installed power locks on my car. For the past month or so, my rear passeger lock works when it wants to. It's become hard to pull manually. Any tips on how to loosen it?
Old Sep 13, 2007 | 02:11 PM
Make sure the linkage is not binding and lubricate the latch and linkage. You may also want to make sure the door alignment is true. As the seals age they compress and this can throw off the alignment when closed.
Old Sep 13, 2007 | 03:56 PM
estunum's Avatar
Will try that this weekend, thanks ken.
Old Sep 14, 2007 | 10:00 AM
XJ40ish's Avatar
No problems with this since. My concern is of course that the darn cat will simply lock the doors unexpectedly when she's running. That might be a problem if one was not near a spare key. Is this something I can expect to continue? Or wold you just leave it for the time being? And most importantly, how much would one of these actuator puppies run me?? I am sitting down.
Old Sep 14, 2007 | 12:01 PM
bigdreams05's Avatar
Crap...talk about Jagzophrenia. Do you have a spare key though? If you don't I recommend getting one...ASAP!
Old Sep 14, 2007 | 12:37 PM
I would check it out first. The 94 models are unique. I'd have to see if I have any used ones.
Old Sep 14, 2007 | 12:38 PM
XJ40ish's Avatar
I have one. And for the next whileI'll keep it handy. The car is going into winter storage mid october anyhow, so I'll probably not worry too much until we take it out next spring. Just put it down to one of those uniquely "Jag" things. Maybe I'll just get another actuator and change it out this winter if I get really bored.
Old Sep 15, 2007 | 10:51 AM
93xj6's Avatar
Take off the door panal and just look at the wires, maybe take off all the panals.
Old Sep 17, 2007 | 06:07 PM
XJ40ish's Avatar
Mine's a 93 Ken if you're rummaging around in your parts bin...
Old Sep 17, 2007 | 06:08 PM
XJ40ish's Avatar
BTW, She only did it the one time, seems to be going through a phase.... Yesterday a lamp warning light, then a check engine, which went out after shutting it off and restarting??? Ahhh Jags... Ya gota luv em...
Old Sep 18, 2007 | 09:53 AM
I call it Jagzophrenia!
Old Sep 18, 2007 | 11:18 AM
XJ40ish's Avatar
The cool thing? My wife was driving it at the time and;
A) Actually noticed the warning lamp was on, and ...
B) Was concerned enough to call me.
Who says miracles can't happen...
Old Sep 19, 2007 | 03:12 PM
I have a used door latch assembly for $150.
Old Sep 20, 2007 | 11:59 AM
XJ40ish's Avatar
Thanks Ken... It hasn't happenedsince my post, so I'm writing it off to Gremlins or those pesky "Jag Gnomes" but I will keep you in mind if it tries it again. BTW if you run across as 1993ish manual I'm still looking for one, or at least one with the newer heating controls covered. I'll get a want list together and see if we can do some business. I'll need to order enough to warrant the shipping costs in any case. Ouchy..
Ran across a 1988 sovereign for $1300.00 CDN, probably could get it for $1000.00 or less... very tempting for a parts donor, but no place to keep it, and there's likely nothing reliable on an 88 anyhow...lol
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
kevinl
Oct 31, 2019 06:15 PM
XJsc-guy
Nov 23, 2015 01:56 PM
mrsimpson
Sep 15, 2015 01:10 PM
