XJ40 ( XJ81 ) 1986 - 1994
egr valve 1993 xj6
Old Dec 23, 2011 | 09:15 PM
robhair's Avatar
Default egr valve 1993 xj6 FIXED !
Having trouble locating egr valve 1993 xj6, seem to be on backorder everywhere I've tried
Old Dec 23, 2011 | 11:21 PM
stimie02's Avatar
Would you be interested in a used one? I know the new ones are pretty pricey. If so let me know. Also correct me if I am wrong but yours has just a vaccuum line going into the top of it and there is no wiring harness connecting anywhere to it. Is it round with a seam going around the middle of it? Just making sure that I am thinking of the correct one.
Old Dec 24, 2011 | 01:48 PM
motorcarman's Avatar
I have a 1992 XJ6 and a 1988 Chevy C2500 5.0 and both had the check engine light on for EGR valve fault.
The Chevy had DTC 32
The Jaguar had FF 39
I cleaned the EGR port in the intake manifold of the Jag but still had FF39
I swapped the EGRs from both engines to see if the valves operated and which one would fault first.
That was several years ago and both operate normally because neither check engine light comes on anymore.
I never did swap back because the Chevy is more difficult than the Jag so I just leave them where they are.
The vacuum ports point in different directions but a longer vacuum line works fine.
You can probably find a Chevy EGR for CHEAP and see if that fixes your problem.
You might not have an EGR problem but a clogged port in the intake!!!!!!!!
What FF code do you have?????????????
bob gauff
Old Dec 25, 2011 | 11:34 AM
robhair's Avatar
same as you ff39, I'm going to see today if maybe the line is just clogged
Old Dec 25, 2011 | 01:02 PM
The Temp sensor 'looks for' a rise in temp when the EGR is commanded 'OPEN". If the port is clogged or the sensor has accumulated carbon and is insulated enough, the ECM will flag a fault for NO RESPONSE from the valve.
The clogged section is in the lower part of the intake just inside (behind) the throttle housing.
Try lifting the EGR vacuum section with your fingers from underneath (A cold engine will keep your fingers from BURNING!!!)
If the engine runs LEAN then the port is open and NOT totally clogged.
I attach a vacuum gauge to the EGR vacuum hose and start the engine. I put the trans in DRIVE and my foot HEAVY on the brake. Hold the throttle pedal open and watch for a VACUUM on the gauge when the revs get to the torque converter stall speed.
If there is vacuum present then that eliminates the EGR control portion of the system.
good luck
bob gauff
Old Dec 31, 2011 | 11:00 AM
robhair's Avatar
I'm considering getting a used one, I'll let you know as soon as I can and yes thaat's the correct description
Old Jan 1, 2012 | 07:39 AM
stimie02's Avatar
Here's one that popped up on ebay. I believe that is the one that you are looking for. Shipping is a little high but it's new.
JAGUAR XJ6 VANDEN PLAS XJS 90-94 NEW EGR VLAVE 4F2000 EGR1867 EBC2737 EGV1108 | eBay
Check it out
Best regards and Happy New Year
Chris
Old Jan 1, 2012 | 08:05 AM
robhair's Avatar
Hey !!! Happy New Year, just bought it !! Thanks so much for your help. I love this forum hahahaha
Old Jan 3, 2012 | 05:52 PM
bmalek's Avatar
Default Fuel Fault 39
Hi Robhair,
I'm having the same problem with my '93 XJ-6. Let me know if you've installed the new EGR valve and whether it took care of the problem.
I haven't been able to pass the smog inspection, and I've already replaced the the oxygen sensor and temp sensor. Still getting that dreaded FF39!
Before shelling out another $100, I just want to make sure it will do the trick.
Old Jan 3, 2012 | 07:09 PM
robhair's Avatar
awaiting part, I'll give you a heads up
Old Jan 5, 2012 | 06:34 PM
robhair's Avatar
Default EGR Fixed !!
Just got my egr from ebay, install took ten minute, no more #39 vcm code and check engine light out !!
Thanks Forum
Old Jan 6, 2012 | 04:44 AM
Cadillac's Avatar
Good to hear that
Check Engine light is still ON on my screen and throws no code
Old Jan 6, 2012 | 02:05 PM
bmalek's Avatar
Thanks for the update. I'll do the same.
1100me
Jul 24, 2023 06:10 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
Boeingtravel95
Sep 14, 2015 05:01 PM
tvholden
Sep 12, 2015 11:13 AM
XFR_Gold
Sep 2, 2015 12:24 PM
