XJ40 ( XJ81 ) 1986 - 1994
Fender
Old Apr 11, 2018 | 02:10 AM
Thumprr1226's Avatar
Default Fender
Okay guys I am confused, what is the difference between a fender off of a 1990 Jaguar xj6 and a fender off of a 1994 Jaguar xj6? can somebody please straighten this out for me. Thanks for the help
Old Apr 11, 2018 | 02:39 AM
Originally Posted by Thumprr1226
..... can somebody please straighten this out for me. .....
A fender bender?
I've moved your question from General Tech Help to XJ40 forum. Members here with the same model will be able to help.
JEPC shows three changes of part number during the production run.
Old Apr 11, 2018 | 11:05 AM
But it looks like the same Fender other than the emblem just being reversed
Old Apr 11, 2018 | 02:44 PM
So the fenders are the same they just change the part number is that right?
Old Apr 11, 2018 | 04:33 PM
jerry_hoback's Avatar
From my "parts " experience, usually a different number means there is Some difference. That could be as simple as a different shaped mount hole. Or it could mean that there was an update to make all parts to that date match a certain definition. Comparing my 92 to my 94 I see no difference. I have never had a 90. If the price is right I would try it.
Old Apr 11, 2018 | 07:00 PM
I've searched UK listings for XJ40 front wings and they mostly refer to "early" as up to 1991. Unfortunately none list the specific difference(s) between "early" and the later pattern.
However, there is a supplier of fibreglass replacements who claims "the centre is marked for the repeater lamp but not cut so you can simply cut to suit the type you have fitted. Will fit all XJ40 models."
From this it sounds very likely the only difference between the part number options listed in JEPC is the side repeater cutout.
Old Apr 16, 2018 | 11:16 AM
db in uk's Avatar
Asd far as I know, the hole cut for the side repeater is the difference between the various model years.
IIRC, there are three types.
Early cars to VIN 629285 used a rectangular side repeater which was grey in colour with a yellow bulb. Cars from VIN 629286 to VIN 687218 used a square yellow side repeater, and 1994MY cars from VIN 687219 used a recessed X300 style side repeater.
Each version of the front wing has a different hole cut in it for the side repeater to fit into. IIRC, the late cars may even have a recessed area for the side repeater unit to sit more flush with the bodywork.
Of course USA and Canada cars didn't have the side repeater so the VIN changes were much less obvious with the car standing infront of you.
There were also three different Jaguar leaper badges used at these VIN points. With a quick Google of the part numbers they look very similar - presumably they attach differently.
Old Apr 16, 2018 | 03:52 PM
Lawrence's Avatar
I think trim strips on some models are riveted on ...lower trim strip on my Sovereign parts car was, IIRC ....however my VDP trim is glued with no holes in the fender. Both are 94MY cars BTW
Larry
JagWatcher
Dec 20, 2007 04:44 PM
notnrml1
Oct 7, 2007 10:08 PM
IronCobra
May 14, 2007 05:07 PM
Nov 29, 2005 10:36 PM
