XJ40 ( XJ81 ) 1986 - 1994
Fueling Failure!
Old Sep 17, 2007 | 09:15 PM
estunum's Avatar
Default Fueling Failure!
Three days ago I got in my car and my message center showed a nasty never before seen exclamation mark. Saying fueling failure. The message remained lit for the entire 25 min drive. I've never seen it before that, and haven't seen it again since then. I tried to rule out some possibilities. The fuel pump got replace about 8 months ago with a new one. Just about 3 weeks ago, got my fuel filter replaced as part of a tune up. What else can it be? Maybe just a one time glitch?
Old Sep 18, 2007 | 09:26 AM
ken@britishparts.com's Avatar
Default RE: Fueling Failure!
Did it give you a code when you hit the VCM button?
Old Sep 18, 2007 | 10:03 AM
estunum's Avatar
It did not give me a code. It came up again yesterday. [sm=insomnia.gif]
Old Sep 21, 2007 | 10:39 PM
estunum's Avatar
Now I'm concerned. It's come up a total of 4 times, and everytime it does it remains lit for the whole ride. It's not just when I turn on the car.
Old Sep 30, 2007 | 11:46 PM
estunum's Avatar
This message keeps coming up, and it seems to come up when the fuel is low. But it has when the tank is full also. Just yesterday I noticed it said "Fueling Failure - 3." It had never given me that 3, what does it mean?
Old Oct 11, 2007 | 11:09 AM
estunum's Avatar
Here's the latest and greastest. I really hope some can give me some advice. The message occasionally comes up, and only one time with the code 3. I'm not sure what to suspect what the problem is. At times, I turn on the car and it will idle really high, between 1500 and 2000 rpm, for a few seconds then come back down. Other times, it oscillates between 900 and 1500 rpm very quickly. One other thing, my car battery is almost dead, I haven't gotten the chance to replace it, but its dying on me, takes either a few cranks or a good long one to get it started. Is the battery related to this? I haven't taken it to the shop becuase I don't have the cash of the time for the next 2 weeks. Help!
Old Oct 11, 2007 | 11:43 AM
Cadillac's Avatar
As much as a bad battery might cause this long cranking a low fuel pressure might cause this too.If your carstarts aftera long cranking when it'shot on the engine try this .Turn the key to 2 and then back to 0 . Repeat the procedure a few times butnever start the engine .After 4-5 attempts turn the key all way to the windshield in other words 3 position .
If it starts quicly like a new car your fuel pressure needs changing
Old Oct 18, 2007 | 11:06 PM
estunum's Avatar
Tried that, continues with the problem. What do you mean by fuel pressure needs changing? The fuel pump?
Old Oct 19, 2007 | 10:08 AM
Press the VCM button when the you see the exclaimation point. This should give you a fault code which will tell you where to start trouble shooting.
Old Oct 19, 2007 | 11:37 AM
estunum's Avatar
Nothing happens when I hit the VCM button. Does my VCM button not work? But, if I turn the key just for all the electronics and not the car and hit it then, it goes through all the icons once, then start to show the exclamation mark. Even then, it won't give me a code. It usually just reads "Fueling Failure" but it has been two random times it reads "Fueling Failure - 3" Is that the code?
Old Oct 19, 2007 | 12:18 PM
That's it! I will try to track down one of the techs and find out what it means.
Old Oct 28, 2007 | 03:41 PM
estunum's Avatar
Another code came up. "Fueling Failure - 8" I did notice that they come up when the car is not on, only on that first click to turn all the electronics on. I usually just take it to the shop at the first sign of failure, but my cash flow isn't too hot at the moment, lol. Maybe I can fix codes 8 and 3?
vsol
Aug 29, 2018 09:46 PM
Pilotman11
Nov 19, 2015 12:55 AM
hoodun
Oct 2, 2015 10:13 PM
mrobinson
Sep 18, 2015 07:20 AM
Tim Goz
Sep 17, 2015 09:11 AM
