XJ40 ( XJ81 ) 1986 - 1994
Oil cooler line leak at block
Old Apr 25, 2019 | 08:54 AM
milan's Avatar
Question Oil cooler line leak at block
Hi,
Have an oil leak from the oil cooler line at block on a 1988 Jaguar XJ6. Car is in collector condition but from what I’m being told by mechanic fixing such a leak with a new o ring could be a terribly difficult job? He says we can try but on such an old car things can go sideways very quickly and then what? Does anyone have experience with these O-rings and if so are our concerns justified? Could we actually damage the cooler line itself by loosening, prying it to replace O-rings? Further to this do we actually need an OEM o -ring or will a similar size work?
please and thanks
Old Apr 25, 2019 | 09:37 AM
Welcome to the forums milan,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XJ40 (XJ6 1986-1994) forum. Members here with the same model will be able to help.
Old Apr 25, 2019 | 01:26 PM
milan's Avatar
Hello again
My car is a 1988 jaguar xj6 red collector condition that needs an oil leak fixed. Apparently the oil cooler line is leaking at block and could be a difficult fix. Is there any kind of work around to this?
thanks
Milan
Old Apr 25, 2019 | 01:48 PM
motorcarman's Avatar
Oil cooler line 'O'ring seals are a common repair.
I suppose the line could be brittle and crack but the 'O'rings are still available.
bob
Old Apr 25, 2019 | 03:00 PM
xjack's Avatar
Not really hard job i did it twice without much problem, perhaps you could also do the filter housing gaskets while there, they also tend to leak, whole project is cheap and doesn't take much time
Old Apr 25, 2019 | 03:23 PM
milan's Avatar
Default oil cooler line
Thanks Xjack
That is really good news, really good news. Now just have to find a mechanic to do this procedure.
Gerry
Old Apr 25, 2019 | 05:50 PM
jerry_hoback's Avatar
I had this not too long ago, I got the o-rings at my local hardware store. It really was an easy one... Good luck.
Old Apr 26, 2019 | 08:25 PM
Roger95's Avatar
I replaced the cooler two weeks ago with the Jag bypass kit.
The cooler hoses are a potential point of failure which gives me heartburn.
Installed a bypass kit and cut and chucked the rear of the two oil hoses and metal pipes.
Removing the cooler itself and the front pipes is more involved and I left for another day.
Old Apr 26, 2019 | 09:09 PM
milan's Avatar
Default oil cooler lines
@Roger
thanks Roger,
Heard of the bypass but didn't know a kit was available? Please where is this available? As a Canadian its frustrating that parts need to come from the USA.
Old Apr 26, 2019 | 09:17 PM
The X300 (AJ16) did not have the cooler but used a bypass devise.
The parts will bolt in to the AJ6 housing.
bob
Old Apr 27, 2019 | 09:09 AM
Roger95's Avatar
The part numbers of the components in the kit are:
EBC4124 (1 per)
EBC4244 (2 per)
CAC5118 (4 per)
Old Apr 27, 2019 | 09:50 AM
Don B's Avatar
Hi milan,
Just to give some visuals, your oil cooler lines connect to the underside of the oil filter housing and are sealed with the O-rings shown as part 9 in the diagram below. The hose half-brackets are secured by nut part 10 that threads onto a stud on the oil filter housing.
You can see the part names and numbers here:
https://www.jaguarclassicparts.com/u...-3-6-4-0-litre
As Bob mentioned, on the X300s (and on the '93-'94 XJ40s), the oil cooler was eliminated and replaced by a "Bypass Pipe," part 4 in the diagram below. It is an aluminum casting that, along with the "Connector" pipes, part 6 (two required) and O-rings, part 7 (four required), simply recirculates the oil back into the crankcase, bypassing the cooler altogether. I believe the bypass pipe requires a longer mounting stud, part 3, since the original cooler hose half-brackets were significantly thinner.
https://www.jaguarclassicparts.com/u...lter-4-0-litre
Cheers,
Don
Old Apr 30, 2019 | 04:32 PM
katar83's Avatar
I didn't even bothered with the bypass on my old 40 and XJS and simply removed the oil cooler block entirely and bolted oil filter housing directly to the block using shorter bolts. Worked/works perfectly fine too.
Old Jun 8, 2019 | 07:35 AM
milan's Avatar
Hello Don B
Thank you very much
now to deal with spongy brakes.
cheers
Milan
Old Dec 12, 2021 | 08:47 PM
dtrain's Avatar
i know this is an old thread:
Having the same oil cooler line leak issue - anyone know the bolt size/length to remove the block and bolt the filter housing directly to the block?
thanks
Old Dec 12, 2021 | 09:31 PM
Lawrence's Avatar
thanks
Could you not remove one bolt, measure it, then deduct the thickness of the oil cooler block (item #1 above) from the total length to get your answer?
Larry
Old Dec 18, 2021 | 07:55 PM
dtrain's Avatar
If anyone is curious the bolts are 8 x 1.25 and the replacements were 25mm long
TXFireblade
Jan 3, 2024 10:51 AM
Cherry_560sel
Sep 16, 2020 09:43 AM
Doug Dooren
Jul 30, 2019 07:25 PM
megacattin
Feb 10, 2019 02:29 PM
MichelB
Feb 4, 2019 08:55 PM
