XJ40 ( XJ81 ) 1986 - 1994
power steering failure
Old Aug 31, 2016 | 04:50 AM
frenchfairplaydriver's Avatar
Default power steering failure
hello this morning starting my XJ40, the steering pump makes a little noise and more support, hard steering wheel, opening the tank of large bubbles in the surface.pas leaks and proper level.
thinking?
Thank you for your opinions
cordially
sylvain
Old Aug 31, 2016 | 10:03 AM
Don B's Avatar
Hi Sylvain,
I'm not sure I understood all the details in your post, but your symptoms typically mean the power steering fluid is low due to a leak. The most common point for a leak is at the low pressure hose from the fluid reservoir to the pump:
Welcome to Jag-lovers - Members Photo Viewing Page
If your fluid level is proper, then I would suspect the power steering pump. I don't know if rebuild kits are still available, but years ago I recall that several members of the Jag-Lovers forum rebuilt their pumps.
Cheers,
Don
Old Sep 8, 2016 | 06:41 PM
jerry_hoback's Avatar
Hi Sylvain- Did you get this fixed?
Old Sep 9, 2016 | 03:12 AM
Default Power steering pompe failure
Hello everyone, thank you for your interest in my problem, I ordered a used pump and seal set for remake the interior sealing.
Old Sep 10, 2016 | 08:35 AM
Good deal. A nice clean one. Hope that does it for you.
jaggedy
Apr 10, 2016 10:07 PM
Humy
Oct 8, 2013 10:38 AM
IronCobra
May 21, 2013 01:44 PM
chprman
May 1, 2008 05:23 PM
Soon2bMD
Feb 16, 2007 12:59 AM
