XJ40 ( XJ81 ) 1986 - 1994
Rear driver side 12 o-clock wheel play help!
Old Jul 29, 2022 | 02:55 PM
YoungBosnian's Avatar
Default Rear driver side 12 o-clock wheel play help!
My wheel started to have negative camber on the driver side rear wheel. I removed the wheel and thought i might not have tighetened the bolts correctly but that wasnt the case. When i apply the breaks while driving i hear a sound under the vhicle from the back i suspected that its from that area as well. I removed the wheel to inspect what might be the issue and i found that there is a lot of 12 o clock wheel play. Ive attached two videos to demonstart the issue. It seems that the axel shaft assembly is loose from the differential. Any input or help would greatly be appreciated!
Regards, Bozzy
https://imgur.com/lFYF2vA
https://imgur.com/VIccdva
Old Jul 29, 2022 | 02:57 PM
Hello, I have a 1991 XJ6 - My wheel started to have negative camber on the driver side rear wheel. I removed the wheel and thought i might not have tighetened the bolts correctly but that wasnt the case. When i apply the breaks while driving i hear a sound under the vhicle from the back i suspected that its from that area as well. I removed the wheel to inspect what might be the issue and i found that there is a lot of 12 o clock wheel play. Ive attached two videos to demonstart the issue. It seems that the axel shaft assembly is loose from the differential. Any input or help would greatly be appreciated!
Regards, Bozzy
Old Jul 29, 2022 | 03:11 PM
motorcarman's Avatar
Differential output shaft bearing.
Common fault with this type of suspension setup.
Old Aug 2, 2022 | 11:47 PM
Don B's Avatar
The photo albums at this link will give you an idea of what is involved in replacing a diff output shaft bearing & seals:
Jaguar XJ40 Differential Output Shaft Bearing Replacement - Part 1 of 2
Jaguar XJ40 Differential Output Shaft Bearing Replacement - Part 2 of 2
The scale of the photos to text has gone wonky since the large images were moved from the old Jag-Lovers servers to the new. Hopefully they will still be helpful.
Cheers,
Don
Old Aug 3, 2022 | 02:47 PM
Where would the part be located on this diagram ?
https://jaguar.lakeridgeparts.com/a/...E300121.html#4
Old Aug 3, 2022 | 09:16 PM
Don B's Avatar
Here's a better diagram, from parts.jaguarlandroverclassic.com . The differential output shaft bearing is part #17, the bearing retaining collar is part #19, and the O-ring is part #16. The shim, part #18, can be re-used:
Cheers,
Don
Old Aug 8, 2022 | 11:54 AM
Appreciate that! I was told by a mechanic in a local shop that it is actually a stub axle bearing that need repair. How accurate is this? And if so where is this part on the diagram?
Regards,
Bozzy
Old Aug 8, 2022 | 11:49 PM
Don B's Avatar
Hi Bozzy,
If he isn't describing the differential output shaft, then I assume he is describing the rear wheel bearings, which are parts #3 and #9 in the diagram below. These are traditional roller bearings that come in two parts, the "cones," or roller bearing cages, and the "cups," or bearing races. The grease seals, parts #2 and #10 should also be replaced. Also, the fulcrum bolt or "pivot pin" bearings, parts #15 (there are two of them) frequently require replacement. Don't be surprised if the pivot pin, or fulcrum bolt, part #14, is rust-seized inside the sleeve, part #13.
The photos and descriptions at the links below show what is involved in removing & replacing these bearings:
Jaguar XJ40 Rear Wheel Bearings R&R - Part 1 of 4
Jaguar XJ40 Rear Wheel Bearings R&R - Part 2 of 4
Jaguar XJ40 Rear Wheel Bearings R&R - Part 3 of 4
Jaguar XJ40 Rear Wheel Bearings R&R - Part 4 of 4
Cheers,
Don
Old Aug 9, 2022 | 07:37 PM
Regards,
Bozzy
See post 3
YoungBosnian
XJ40 ( XJ81 )
Jul 29, 2022 02:57 PM
woodturner
Dec 13, 2018 02:17 AM
tommyd
Mar 19, 2015 01:55 PM
tommyd
Mar 19, 2015 01:53 PM
Robin Parry
Jan 26, 2012 05:08 AM
