XJ40 ( XJ81 ) 1986 - 1994
Which Stereo, Head Unit, Entertainment System
Old Jun 14, 2009 | 11:04 PM
woodpuppy's Avatar
Default Which Stereo, Head Unit, Entertainment System
I am thinking about replacing the factory audio system in my 1992 XJ-6 Sovereign and I wanted to ask what system and/or components others have used in similar model Jags.
I'm hoping there is a replacement system that will fit nicely into the factory opening.
Thanks for your input and suggestions in advance.
Old Jun 20, 2009 | 02:25 AM
1988xj6navy's Avatar
http://www.crutchfield.com/S-BDlV4Vc...ckney_XJ6.html
I found this on line and it looks nice with what they did, and just to let you know 6 1/2 woofers will fit in the locations under the back seat. You have to do some mods but they will fit without hurting the car. I have an 88 I plan to put 4 inch Audiobahn ABC4002V or Pioneer Premier TS-D402P in the doors, and put 2MA Audio MA65B 6.5" Mid-Bass Woofers below the back seat. I will power the 4 inch doors off the Pioneer head unit I forget the model number. And power the two subs off of a Alphasonik PMZ1502, so 25x4 rms will be going to the doors and 2 x 75 to the subs. It should be a rocking system.After that I am going to re clear the car using house of color clear with a blue pear added to give it a different look(should look good over the factory navy). I am going to keep the stock wheels and refinish them but do it different than you would think. I am going to use a Mirage MP-404 Ice Kit from duplicolor and apply 3 coats of clear over it,its awesome it is silver but changes every color of the rainbow in light. I wonder how it will look on the wheels,I guess we will see. But before all that i got to sort out the car and get the basics first then on to the fun stuff. I have plans for it,its going to be sweet when i fix it like i want it. I am keeping it stock all but this.
Old Jun 21, 2009 | 08:58 PM
woodpuppy's Avatar
Thanks for the link and info. I understand about sorting things out. I thought I had completed that phase and was on to the fun stuff as you put it, but then the A/C compressor died a few days ago. So now the audio system funds are going to redo the entire A/C system so I don't have to worry about it any more.
Good luck with your ride. Post a few pictures when you get it completed.
Old Jun 21, 2009 | 09:20 PM
I will I got to do the transmission fluid change now,I am researching for another fluid beside esso. I am thinking amsoil but,we will see.
Peace
Old Jul 7, 2009 | 05:55 PM
woodpuppy's Avatar
Default Thanks
Thanks for the info. I've found a solution that I like. I need to close this thread,
Old Jul 7, 2009 | 09:35 PM
ArmyJag's Avatar
What did you end up going with?
I went with a Clarion FB275B
http://carstereo.files.wordpress.com...01/fb275bt.jpg
Old Jul 17, 2009 | 11:45 PM
Nothing yet Im broke fixing the other stuff.
mbergen
Oct 23, 2019 10:26 PM
Dz1rfj
Jul 17, 2018 10:29 AM
jdzubas
Oct 4, 2015 09:14 AM
Dz1rfj
Sep 16, 2015 03:44 PM
Mike Green
Sep 7, 2015 12:39 AM
