backfire through intake..
Ok, while my car is down and waiting on the cam bearings to show up i thought i might pick everyone's brain as to why i get a backfire through the intake, only when engine has been running for about a minute and one only once!
Engine runs beautifully before and after it! Basically, i start the car, back out of driveway, got to stop sign, pull through, go to next stop sign and then get a hesitation and a small pop through intake and off she she goes!
its gotta be something simple!, im thinking maybe its happening right as the csi stops and its just not quite warm enough! Any ideas? anyone? anyone?
As a side note, when i had all my issues with csi and thermotine being plugged into each others harnesses i did fiddle with the spring in the mass air box ( still sick and cannot think of its name), but i counted the teeth i moved it and moved it back the same amount.
Of course messing with a 30 year old spring wasn't my finest hour! but can it be possible the spring doesn't have the tension it should after my messing with it????
you guys have time to ponder this as i just ordered my cam bearings today, after they come in i get to measure and order the valve shim!! looking at two weeks before im back on the road!
Received 2,399 Likes
My comment is a generic one as my expertise, if it even exists, is not on this engine!!
A pop in the intake can only come through an open intake valve.
So, when you freshen the cam bearings and clearances , it might just go away.
I've never heard of a cam gong flat in an XJ engine, but they do in others. But, this is an open issue and possibly clearance as well.
How to check for lobe wear? In an experinced engine it might be considerable.
1. A dial indicator and degree wheel. duration and openings.
2. A very careful visual. With calipers or better yet, a micrometer.
Not as accurate as 1, but could be indicative.
Carl
Carl
Received 10,802 Likes
Lean mixture/fuel starvation
Coolant temp sensor, perhaps. It might not be giving a 'cold engine' signal to the ECU.
The cold start injector circuit can operate only when the key is in the 'start' position.....so it's out of the picture as soon as the engine starts
Possible, but hard to confirm.....
BrentGardner
28
04-26-2024 03:08 AM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
MLRocafella85
07-28-2011 04:40 PM
