Borg Warner 66 Trans Slipping
Old Jun 8, 2023 | 08:55 AM
Childeric12's Avatar
Default Borg Warner 66 Trans Slipping
Hi Everyone!
My transmission seems to be slipping in reverse only. It will back up ok if on a flat surface but, it will slip if I back up on a slight grade. I checked and tightened the bands which were loose. I also adjusted the ATF level. Car has only 41,000 miles. Just curious if anyone thinks this might be repairable without having to rebuild the whole transmission? I know it is difficult to say without actually seeing the car, etc. I'm just curious what everyone thinks. Thanks!!
Old Jun 10, 2023 | 06:57 AM
metalbasher's Avatar
Sounds like the reverse band is adjusted incorrectly or there is a hydraulic pressure issue with the servo that actuates the reverse band. Your valve body could also be dirty. Did you change the fluid and filter screen or just add ATF?
Old Jun 10, 2023 | 02:00 PM
I just topped off the ATF. It was 1 1/2 quarts low. I adjusted the reverse band to 5 ft pounds and then backed off 3/4 of a turn.
Old Jun 14, 2023 | 10:08 PM
I tightened the bands a bit more (5 ft/lbs and then back off 1/4 turn) and it is better, but still slips under load. I'm thinking of trying 5 ft/lbs and not backing off at all to see if that is better. Any thoughts?
metalmarty
Nov 3, 2014 06:42 PM
86jag
May 23, 2013 04:35 PM
todski2
XJ40 ( XJ81 )
Jul 23, 2012 02:00 AM
jonre
Apr 30, 2010 03:16 PM
jensenguy
Aug 14, 2009 12:43 PM
