Different Fuel Rails - Series 3
Old Feb 9, 2021 | 03:24 PM
Naber's Avatar
Default Different Fuel Rails - Series 3
Hello,
After receiving a new fuel pressure regulator for my 1983 XJ6, I quickly realized I didn't have the right part... Instead of all three fittings (2 fuel + 1 vacuum) be a beaded hose fitting... instead one of the fuel fittings was threaded. Upon closer inspection, it looks like some cars were fitted with a straight fuel rail that is compatible with the threaded fitting (color image below) and those with a circular style that require all barb fittings (b/w image below).
Question... anyone know why the deviation exists?
Thanks!
Nick
Old Feb 9, 2021 | 11:19 PM
Jag-o-nomic's Avatar
Hi Naber,
Yep, earlier engines had Fuel Pressure Regulator EAC1284
Later engines had Fuel Pressure Regulator EAC4864
And, no they are not interchangeable.
Cheers,
Nigel
Old Feb 10, 2021 | 03:35 AM
Fraser Mitchell's Avatar
The earlier fuel rail that I had on my 1980 was an absolute PITA, as it was very prone to leaking where the flexible pipes joined it. In addition, I understand the later one is less prone to fuel vaporisation due to heat. The later fuel rail is a lot better, so if you can, swap them over.
Old Feb 10, 2021 | 08:48 AM
Naber's Avatar
Originally Posted by Jag-o-nomic
Hi Naber,
Cheers,
Nigel
Thank you for the quick and helpful reply! I thought I was going crazy... and given the later is more preferable, it gives further evidence that the XJ6 I purchased is extremely original. thanks again.
Pirk
Nov 6, 2020 01:48 AM
Artfulkatana
Sep 25, 2020 12:17 PM
worzella
May 26, 2020 07:17 AM
garvan61
XJ40 ( XJ81 )
Jul 18, 2018 12:05 PM
jaxley11
May 4, 2014 03:20 PM
