Hose Fitting EAC2860
Hello, I'm in the middle of replacing the water pump on my 1987 Vanden Plas, and am having trouble removing the EAC2860 hose fitting. Does anyone know where I can find a replacement for it? I've searched around quite a bit and haven't had any luck. Thanks.
https://mossmotors.com/c17421-by-pass-hose-adaptor-5-8
Is this the same one you are looking at?
Rgds
David
I have one just like the picture posted above by David84XJ6.
The one circled in your images I had not seen before, it does seem smaller.
Have you checked with SNG Barratt USA store ?
I didn't see any listed, but I contacted them for good measure. Seems strange that the other two fittings get included with a new water pump, but not this one.
yes, they can get parts from UK that are not listed in the website. Another source could be David Manners in UK.
If you can't get the fitting thru normal channels, I have order BSPT pipe fittings from China before for my XKE. There are two kinds of British pipe thread one tapered and one parallel. First you have to determine the measurements. Also have gotten them in SS, although there is less selection. Masters Catalog may have BSTP size you need also.
https://www.ebay.com/itm/363749216982?hash=item54b12492d6:g
DYAAOSwQM1iHy2 b&amdata=enc%3AAQAIAAAA4A49YvG%2Bp%2F69jEYLNoK8xEo 4k6%2BGorW1%2F0aAkv0V36HFdgd09y9ZET9Qjg0udPXpXpqZZ eJSAogt9he6sGZRc60TZmQwPxYot6JYLLadt6XDS57jH2qMWEw %2F24ZahdbY%2BLhaHqel3723%2Bhs00OquhaT253eE4tLdatw 3V6nlkOsGj99Mha1Cpq8Z9syctV%2Bag1tyPctGDQvgoHxzA9N foYjvLAoZYESnsRQHXHgvKGRdScjuPIeLrBdzrBMjZ3IpLQEVy v8p9Loo6nBOAPk9%2BvYpH1ihxeSwdpBYrklcopW1%7Ctkp%3A BFBMlNu9o-Ji
https://www.ebay.com/itm/18266617154....c100667.m2042
Rgds
David
DYAAOSwQM1iHy2 b&amdata=enc%3AAQAIAAAA4A49YvG%2Bp%2F69jEYLNoK8xEo 4k6%2BGorW1%2F0aAkv0V36HFdgd09y9ZET9Qjg0udPXpXpqZZ eJSAogt9he6sGZRc60TZmQwPxYot6JYLLadt6XDS57jH2qMWEw %2F24ZahdbY%2BLhaHqel3723%2Bhs00OquhaT253eE4tLdatw 3V6nlkOsGj99Mha1Cpq8Z9syctV%2Bag1tyPctGDQvgoHxzA9N foYjvLAoZYESnsRQHXHgvKGRdScjuPIeLrBdzrBMjZ3IpLQEVy v8p9Loo6nBOAPk9%2BvYpH1ihxeSwdpBYrklcopW1%7Ctkp%3A BFBMlNu9o-Jihttps://www.ebay.com/itm/18266617154....c100667.m2042
Rgds
David
ACE Hardware, Home Depot, and Lowe's.
I have not seen any British Standard Pipe (BSP) fittings in US stores shelfs. Threads per inch are different that US pipe fittings...
Rgds
David
Rgds
David
b
AI Bsp British Standard Pipe Bspp Parallel Tap And Die Set - 8 Size 1/8 To 1 - Amazon.com
(4.4)
Price: $159.49
amazon.com› BRITISH-STANDARD-PIPE-BSPP-PARALLEL › dp › B07QXX96KN">
amazon.com› BRITISH-STANDARD-PIPE-BSPP-PARALLEL › dp › B07QXX96KN" /> amazon.com› BRITISH-STANDARD-PIPE-BSPP-PARALLEL › dp › B07QXX96KN">amazon.com› BRITISH-STANDARD-PIPE-BSPP-PARALLEL › dp › B07QXX96KN
AI Bsp British Standard Pipe Bspp Parallel Tap And Die Set - 8 Size 1/8 To 1 - Amazon.comAI Bsp British Standard Pipe Bspp Parallel Tap And Die Set - 8 Size 1/8 To 1 - Amazon.com
(4.4)
Price: $159.49
https://www.ebay.com/itm/294669316397? Brass Fitting Adapter BSP-NPT 1/4" Male BSPT to 1/4" Female NPT Euro to US
New Price: US $7.99 Free Standard Shipping
Other sizes offered by this distributor in California
Rgds
David
Rgds
David
kr98664
Dec 31, 2022 01:56 PM
Currently Active Users Viewing This Thread: 4 (0 members and 4 guests)
