Ignition Switch Wiring HELP!
Old Apr 30, 2013 | 04:14 PM
DreWRoolZ's Avatar
Default Ignition Switch Wiring HELP!
Does anybody know where I can find a wiring diagram for the ignition switch on a Series 2 XJ12? Any help would be greatly appreciated as I can no longer drive it until I fix the wiring problem thanks in advance!
Old May 2, 2013 | 11:38 AM
JagCad's Avatar
My stuff only has the Jaguar publication S57 for S3 cars. Whether or not it is the same or similar to your car is unbeknownst to me. if you contact me PM I'llbe glad to share a scan of the appropriate page.
Or, check Captainjaguarscathouse, an Australian site with a lot of very useful stuff.
Carl
Old May 2, 2013 | 01:43 PM
Roger Mabry's Avatar
Default SII wiring and key to the charts
Try these..sorry but they will not upload here as they are .tif files.
Will send them Privately..if you give me your email address.
Last edited by Roger Mabry; May 2, 2013 at 01:47 PM. Reason: .tif files do not work here to upload
Old May 2, 2013 | 02:26 PM
Paratrooper54's Avatar
This site was very helpful for me http://www.captainjaguarscathouse.co...ec%20Guide.pdf
Old May 3, 2013 | 07:32 AM
DreWRoolZ's Avatar
thanks I found the wiring thing I needed but now I have another problem.. how do I take the ignition lock cylinder out or how can I bypass the thing that locks the steering wheel?
Old May 3, 2013 | 08:03 AM
Doug's Avatar
If it's like a Ser III (I suspect it is) the lock assembly is held in place with shear bolts....which will have to be drilled out.
On shear bolts the hex head snaps off at xxx-amount of torque, leaving just a pointy nub.
Old May 3, 2013 | 08:11 AM
S.Bunzel's Avatar
I Hope this will help you!
Old May 3, 2013 | 11:28 AM
DreWRoolZ's Avatar
it's a Series 2 but I think it's the same.. so if I drill those out will it mess up my steering column or anything?
Old May 9, 2013 | 05:53 PM
geneo's Avatar
I have recently done this procedure on my 95rover and alfa. The jag is next. Keys were stolen, including the backups, duringa home burglary. It’s not easy to drillin that area so normally you use a small hacksaw to saw in a new groove, or (as I did) use a little chisel to tap it loose. Worked easy.
eurotire
Sep 18, 2015 07:27 AM
jagent
Sep 12, 2015 01:40 AM
1964Daimler
Sep 9, 2015 11:28 AM
avern1
Sep 8, 2015 06:25 PM
laserguy
Sep 3, 2015 02:02 PM
