Kick-Down cable 1986 XJ6
Old Sep 15, 2022 | 02:43 AM
mikega's Avatar
Default Kick-Down cable 1986 XJ6
Hello
please is it possible to take out the kickdown cable down from the transmission side?
How would I do that if possible?
Old Sep 15, 2022 | 06:35 AM
Doug's Avatar
The cable attaches to a small lever inside the transmission. I believe you can access this connection by simply removing the transmission pan. Search the archives; I recall someone posting pictures many years ago
Old Sep 15, 2022 | 06:50 AM
yachtmanbuttson's Avatar
Doug is correct; not a hard job on a BW66. I've done it. Yes, have to remove the pan. And the adjustment after assembly is pretty ticklish without a pressure gauge. But you can get it correct with patience. I would replace the transmission filter and gasket while you are at it.
Adjustment inside transmission
Adjustment outside transmission, inside engine compartment
Gear-shift change speeds
Old Sep 15, 2022 | 09:55 AM
mikega's Avatar
The kickdown wire is broken or torn off and I need to do a magic or weld it back and that the reason I want to remove that cable assy.
Old Sep 15, 2022 | 01:16 PM
Your pics look totally different from mine! Not sure what you have.
Old Sep 15, 2022 | 03:33 PM
mikega's Avatar
mine is on/from a series 3, how about yours?
Old Sep 17, 2022 | 06:50 AM
Series II - 1975 T/Strombergs, BW66
Old Sep 18, 2022 | 05:17 AM
Robert Laughton's Avatar
The S2 would have a 65 gearbox, with similar cable operation, but as it has carbs, it pulls from the linkage, whereas the S3's 66's pull from the throttle.
Rob
mikega
Aug 21, 2022 05:56 AM
Harvestwidow86XJ
May 25, 2021 10:54 AM
VanTrans
Canada
Nov 16, 2018 11:39 AM
Purplemaverick
Jul 3, 2017 03:43 AM
alabbasi
Jun 23, 2012 03:28 PM
