Lucas wiper system
Old Dec 24, 2022 | 04:12 AM
No Quarter's Avatar
Default Lucas wiper system
Hi, trying to get it running on 73 XJ6 S1. The near-motor wheelbox, the axis inside is almost seized and neither WD40 nor exercise has helped a lot. Besides buying a new wheel box, is the one I have something I can dismantle, if the plate is removed, can the axle be pushed/hammered out, or is the wiper arm spindle on the top pressed on so it's not possible?
Old Dec 25, 2022 | 10:27 PM
Andy T.'s Avatar
I have a Lucas wiper wheelbox from a different British car (a Hillman actually) in my oddments box so just took a look. I’m pretty sure this will be the same basic design as the Jaguar one perhaps with different gearing ratio.
if you remove the rear cover plate, the gear that is driven by the cable from the wiper motor has a spline where it joins to the spindle for the wiper arm. It looks like it should be possible to press it out if required.
The other end where the wiper arm connects is a hollow splined gear that slides over the end of the shaft tube, so spraying WD40 from the top probably has not managed to get any into the shaft tube
Old Dec 26, 2022 | 06:38 AM
Fraser Mitchell's Avatar
You have to take off the top of the dash to get to the wheelboxes. However, when you squirted WD40, did you first remove the chrome escutcheon situated just below the wiper arm ?
Old Dec 26, 2022 | 06:46 AM
Jose's Avatar
WD40 will not get it freed. Try PB Blaster before resorting to brute force.
Old Dec 26, 2022 | 08:59 AM
No Quarter's Avatar
Thanks, ordered a new wheel box now, got the old one out, can't be moved without tools and force.
Old Dec 26, 2022 | 04:48 PM
JagCad's Avatar
Aye. WD 40 was developed a s a desicant.
Other options are far better. Liquid wrench. even just any light oil.
Old Dec 31, 2022 | 06:10 AM
No Quarter's Avatar
OK, thanks for input, I've now got the mechanical part sorted, wipers move freely when I work the cable without motor. Now to the electrical part, so Lucas wiper motor specialists etc., please chime in...
First, this car of a friend, it's not had an easy life. The wipers didn't work, the motor was held together with cable binders, the wiring was "cheated" by using only 3 of the 5 wires in the original wiring, and I see home made wiring on the switch behind the fold down plate. So more or less nothing is as original I think.
A new motor doesn't work, so I started analysing. Found this online:
My new motor and the original wiring have this 5 wire connector. On the original wiring however, 2-3-5 are correct, but Earth (black) is in position 4, and Live (Ignition on, White/Green) is in position 1. Is this from the old positive earth days? It's a 1973 XJ6 S1? Or is my motor wrong, Is there another motor I should have gotten that has switched 1 and 4 also?
Both the held-together-by-cable-binders-old-motor and the new looks the same, and has 16W markings on them.
Any suggestions? Thanks
Old Dec 31, 2022 | 01:48 PM
LT1 jaguar's Avatar
Active Streak: 60 Days
This info is for my 1985 S3 and I don't know if any will apply to your S1.
The link covers a modification I did to the wiring on the wipers and might give you some help identifying yours.
https://www.jaguarforums.com/forum/x...pgrade-232181/
Dave
Old Jan 1, 2023 | 07:18 AM
No Quarter's Avatar
Excellent drawing Dave, helped me understand and fix this, which in the end meant taking parts from the old and "new" wiper motor and combine. It now works, and can even park... :-)
Old Jan 1, 2023 | 01:28 PM
LT1 jaguar's Avatar
Glad to help.
Dave
Sean B
Dec 8, 2022 07:42 AM
paddyx350
Mar 21, 2022 05:57 AM
DanielEllensjag
Jan 14, 2020 12:41 PM
clivedavies
Dec 18, 2015 10:28 AM
nebelfuerst
Feb 6, 2013 06:10 AM
