S3 Exhaust front downpipe
Old Feb 11, 2021 | 07:43 AM
iramphal's Avatar
Default S3 Exhaust front downpipe
Does anyone know if this downpipe from SNG Barratt is a direct replacement for the pipe that I have on my 1985 S3 (Canada with Catalyst can). I'd dearly like to replace the factory one with one of these.
https://www.sngbarratt.com/English/#...b-fe0b61047b2f
Ian
Old Feb 11, 2021 | 10:03 AM
Darrenmb's Avatar
Veteran: Navy
That’s what I put on my 83 before I lumped it, you will need to weld in an o2 bung!
Old Feb 11, 2021 | 10:24 AM
iramphal's Avatar
Darren, Did you use this specific SNG part? Was it a straight swap or was additional fabrication/modification required? I understand about the O2 sensor bung needing to be welded in.
Ian
Old Feb 11, 2021 | 10:54 AM
Darrenmb's Avatar
Veteran: Navy
Mine came from Paul’s jaguar , looked the same, however I also replaced the mid pipe with a non cat one, so cannot say how well it would have lined up with stock pipe, guess I should have mentioned that, sorry
Old Feb 11, 2021 | 04:45 PM
Jose's Avatar
the SNG link does not show the pipe.
But if it is the Euro downpipe, ( no cat, no O2 bung ). it should fit. Also there is a Euro Y pipe to replace the Y pipe with cat.
Just cut the bung from the cat and weld it into the Euro pipe.
Old Feb 12, 2021 | 08:22 AM
Robert Laughton's Avatar
Ian, have one from a S2. It may fit.
Rob
Old Feb 13, 2021 | 07:09 AM
iramphal's Avatar
I've been looking at various parts catalogs, SC Parts Group, SNG, Welsh etc and they all show differing part numbers for the Series 1,2 and 3 models. There are also downpipes with 4 hole manifold flanges and 2 hole ones, but I assume either flange design would work. I'll contact the various companies next week and get their advice.
Old Feb 13, 2021 | 09:25 AM
Doug's Avatar
The most current number (that I'm aware of) is EBC9388. The number has changed several times as evidenced by the illustration below.
brinny
Jul 12, 2020 02:46 PM
Fla Steve
May 29, 2018 12:28 AM
John Gloyd
Mar 3, 2016 11:42 AM
bollocsk187
XE ( X760 )
Feb 18, 2015 09:25 AM
JagYour
Aug 28, 2011 12:37 AM
