Series 2 front discs on series 1 xj6?
Old Feb 25, 2016 | 10:30 AM
Matt jag xj6's Avatar
Default Series 2 front discs on series 1 xj6?
Does anyone know if i bought xj6 series 2 vented front brake rotors could i put them on my series 1 xj6? Could you use a spacer in between both sides of the calipers to give more room for the extra width of a vented disc like people do for the rear brakes. Thanks
Old Feb 25, 2016 | 10:45 AM
icsamerica's Avatar
Dont use a spacer. Get a complete series 3 spindle. There a numerous design imporvements and the whole spindle is a bolt on.
Old Feb 26, 2016 | 04:37 AM
Ok sounds good. Could you please clarify what a complete spindle is? Thanks
Old Feb 26, 2016 | 05:12 AM
Daf11e's Avatar
Matt I think he's referring to the hub...as in spindle hub.
Old Feb 26, 2016 | 08:43 AM
icsamerica's Avatar
The complete spindle is everything between the upper ball joint and lower ball joint.
Old Feb 26, 2016 | 12:01 PM
XJeej's Avatar
Yes my series 1 has calipers with 4 pistons and vented discs, much better. Brakes are good.
Old Feb 26, 2016 | 10:55 PM
Awesome! Thats what i wanted to hear. thanks guys
Old Feb 27, 2016 | 01:31 AM
Does the master cylinder need changing or will the series 1 master cylinder work fine with the series 3 calipers? And one last question and i'll leave you in peace. Is the rear brakes on non abs xj6 series 1,2 and 3 the same? Calipers and rotors? Thanks again you have been very helpful.
Old Feb 27, 2016 | 07:48 AM
Fraser Mitchell's Avatar
I did think they're all the same, but Series 3 shows different part numbers. AFAIK the Series 1 & 2 are interchangeable, but this is Jaguar ! Much may depend on when changeovers were made, it could be partway through Series 2 production.
Old Feb 27, 2016 | 09:16 AM
icsamerica's Avatar
Master Cyl doesn't need changing, the bore size was the same (15/16ths) from 69 XJ all the way to the late 80's. Series 1 and 2 have remote reservoir. You can upgrade to a series 3 master if you want to do away with the remote reservoir and have better availability of parts.
The Only XJ Series 3 to ever have ABS was the 90's XJ12, those are rare and I've never seen one in the flesh. As for the rear brakes there are many differences from series 1, 2 and 3 relating to how the caliper mounts to the diff and routing of the pressure lines and how the exhaust hangs. Size and effectiveness is all the same until Jaguar changed to rear outboard brakes on the last few years of XJS. That setup is drastically changed for ease of maintenance, cooling and braking force.
Old Feb 27, 2016 | 12:03 PM
Thanks for your help. I do look into this stuff myself but some things i find heaps of info other things i find nearly nothing. You guys are bloody champions! Cheers
NathanDD6
Jun 1, 2024 11:43 PM
Kopi
Feb 19, 2016 08:41 AM
DevlinC
Feb 14, 2016 03:24 AM
Cherry_560sel
Feb 11, 2016 09:50 PM
o1xjr
Jan 28, 2016 08:29 AM
